Vtec help????
Old Apr 25, 2007 | 03:47 PM
civic_jdm16's Avatar
Default Vtec help????
OK so my friend has Like a 95 lude. It had that single cam in it. Well he just put an H22 in it and his Vtec dosn't work..... Every thing is right as far as the swap goes....
I heard he should just get a vtec controller..... '
Any thoughts????
Old Apr 25, 2007 | 04:29 PM
CB7 ghost's Avatar
Default Re: Vtec help???? (civic_jdm16)
VTEC solenoid needs to be wired to the ECU.
Old Apr 25, 2007 | 04:55 PM
Default Re: Vtec help???? (CB7 ghost)
OK thats not the issue, But thanks anyway
Old Apr 25, 2007 | 05:26 PM
russlan44's Avatar
vtec controller wont fix it, all it does is u can set the vtec to ingauge at whatever RPM u want from 3000 and up
Old Apr 25, 2007 | 05:56 PM
preludefien
Guest
Posts: n/a
Default Re: Vtec help???? (russlan44)
does it throw any codes..and no a v tec controller want solve anything...you cant get it and expect to control when v tec hits when its not working from the jump.
Old Apr 25, 2007 | 06:12 PM
thegeorge613's Avatar
Tell him to check his oil, his VTEC solenoid, and his wiring.
Old Apr 25, 2007 | 07:01 PM
jdmlude5
Guest
Posts: n/a
make sure the oil pan is not dented. it could block the oil pickup. it has happened to me.
Old Apr 25, 2007 | 07:57 PM
guitarlude26's Avatar
Default Re: Vtec help???? (jdmlude5)
yes make sure you have enough oil, vtec won't engage otherwise. If that was the problem though, you might be coding for it.
Old Apr 25, 2007 | 09:13 PM
streamlineluder's Avatar
Default Re: Vtec help???? (guitarlude26)
vtec solenoid could be bad
Old Apr 25, 2007 | 09:40 PM
Default Re: Vtec help???? (thegeorge613)
No codes oil is good
Old Apr 26, 2007 | 05:30 AM
preludefien
Guest
Posts: n/a
well check the ground....theres no way everything is fine and its still not working..theres something wrong.
Old Apr 26, 2007 | 10:23 AM
Default Re: Vtec help???? (preludefien)
well thats what I said,,,, but it seems to be that way let me get some more info on it
Old Apr 26, 2007 | 08:15 PM
OK I seen the kid tonight, turns out he just started to get a very bad oil leak
Old Apr 26, 2007 | 10:14 PM
preludefien
Guest
Posts: n/a
well thats why my friend..vtec want engage with a low oil level...
Old Apr 26, 2007 | 10:21 PM
Well thanks for the help Guys... I will let ya know how it runs when its fixed!!!
BlueSmartEm1
13
Jul 3, 2011 09:26 PM
B20_SI_CRX
21
Jun 8, 2005 10:03 AM
H22A_HB
Oct 22, 2004 11:10 PM
CompressionFed
Mar 23, 2004 04:54 AM
Kp_VtekNiks
May 10, 2002 10:53 PM
