radio install help
Old Apr 25, 2007 | 03:42 PM
the1337couch's Avatar
Default radio install help
i am puttin a radio in my crx and i cant find a accessory wire. i have tried all the wires and none of them work. i wired the radio directly to the battery and it works but i need to find an accessory wire so it will turn off when the car does. on the diagram it says the blue/white wire is the switched 12v and the yellow/red is the constant but it doesnt work when wired like that. i was gonna wire it to the power wire going to the fuel pump because it turns off when the car does. any suggestions to help?
Old Apr 25, 2007 | 03:48 PM
91ed9's Avatar
Default Re: radio install help (the1337couch)
if thats the case why not wire it up to the extra slot on the fuse box inder the dash
Old Apr 25, 2007 | 03:50 PM
NHswaps13203's Avatar
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
Default Re: radio install help (91ed9)
well the fuse for the ign power is under tha dash and the constant is under the hood, they are there and they are blown, trust me i been installin stereos for the last 6 years,
Old Apr 25, 2007 | 03:53 PM
well all the fuses under the dash are good. i checked every one of them and the fuses under the hood are good too :/ i just need a accessory wire to tap into so i can install my radio. any other wires i can tap into?
Old Apr 25, 2007 | 04:04 PM
91ed9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91ed9 &raquo;</TD></TR><TR><TD CLASS="quote">if thats the case why not wire it up to the extra slot on the fuse box inder the dash</TD></TR></TABLE>
Old Apr 25, 2007 | 04:16 PM
Default Re: (the1337couch)
i belive its pin 2
Old Apr 25, 2007 | 05:37 PM
i just looked at the fuse box and im stumped at how to tap into it.
Old Apr 25, 2007 | 06:15 PM
any help would be appreciated. i need to do it asap
Old Apr 25, 2007 | 07:08 PM
bump
Old Apr 25, 2007 | 08:20 PM
bump
Old Apr 25, 2007 | 08:36 PM
gokblok's Avatar
what happened to the stock wiring harness? It would be attatched to that . . . if you're using that harness it's definitely a fuse or the wire is compromised somewhere. If you're not using the factory harness, what are you using?
Old Apr 25, 2007 | 09:07 PM
i was using the factory harness but the accessory wire wouldnt work. and i checked all the fuses and none were blown. i thinkim just gonna take it to mobile one or something
Old Apr 25, 2007 | 10:04 PM
95f22a1's Avatar
hook it to your cigarette lighter fuse. thats how i have mine ran.
Old Apr 26, 2007 | 10:53 PM
Efbluevtec's Avatar
use a test light and find an empty slot or tap into the opposite side radio fuse under the dash. tap into the side that doesnt get power so the power passes through the fuse first then the wire. to tap in...expose some wire at the end and wrap it around one side of the fuse then push it in. easy way to do it
Old Apr 27, 2007 | 02:20 PM
cool thanks man. ill try that when i get home
Tyler Harteau
Oct 18, 2018 09:19 AM
I Love My 4 door
Dec 19, 2010 04:05 PM
matchewspoo
May 2, 2010 01:47 PM
efjones9
Audio / Security / Video
Jun 10, 2009 08:33 AM
89civicsiowner
Jun 5, 2009 09:53 AM
