timing help
Old Apr 25, 2007 | 12:16 PM
mpower325's Avatar
Default timing help
i think my civic is off timing how do i check if it is since it wont start and i cant use a timing light
Old Apr 25, 2007 | 01:53 PM
ddd4114's Avatar
Default Re: timing help (mpower325)
How did you conclude that your timing is off?
I assume you checked for spark, fuel, and compression?
Old Apr 25, 2007 | 02:49 PM
phantomeg6's Avatar
what kinda motor are u running? maybe u just need to advance ur distributor way past its suppose to. have someone turn the distributor while u try to crank it. make sure there arent any bolts so u can just keep on turning it way past its suppose to.
Old Apr 25, 2007 | 04:41 PM
mpower325's Avatar
Default Re: timing help (phantomeg6)
yea i had a different distributor plugs wires and everythin the only thing left is my timing
Old Apr 25, 2007 | 05:31 PM
The Si's Avatar
your timing belt probably skip a tooth.
Old Apr 25, 2007 | 05:33 PM
Suck my DX's Avatar
Default Re: timing help (TheSi)
set the crank to TDC and check if your cam gear/s is/are alligned properly....
Bassy_budz
68
Dec 16, 2013 08:38 AM
dannyk89
Nov 4, 2008 08:16 AM
97gsrki
Nov 15, 2007 11:31 AM
HTn00b
Mar 10, 2007 10:17 AM
wpgcivic
Jan 16, 2005 06:15 PM
