quick oil change question.
Old Apr 25, 2007 | 10:44 AM
illestaznpimp's Avatar
Default quick oil change question.
i have a 97 gsr motor with a moroso oil pan. i was told that i should only put 4.25 quarts of oil for a gsr motor. but i've put almost 4.5 and my dipstick still isnt reading anything. is it most likely because of the moroso oil pan? should i put more til the dipstick reads? thanks
Old Apr 25, 2007 | 10:47 AM
ek4h's Avatar
Default Re: quick oil change question. (illestaznpimp)
just start up your car
Old Apr 25, 2007 | 10:49 AM
WihaSi's Avatar
I have a stock 98 EJ6 and when I change my oil it does the same thing. I just let it sit for about 2 mins, then it'll read.
Old Apr 25, 2007 | 10:52 AM
Padawan's Avatar
Darth ModerVader
It is most likely due to the aftermarket oil pan, which I believe has a higher oil capacity. Go by what the dipstick tells you, not just the fluid amount that you've poured in.
Old Apr 25, 2007 | 11:11 AM
B16b-EJ8's Avatar
Default Re: quick oil change question. (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">It is most likely due to the aftermarket oil pan, which I believe has a higher oil capacity. Go by what the dipstick tells you, not just the fluid amount that you've poured in. </TD></TR></TABLE>
Agreed, I would check the specs on the pan and see how much it hold versus how much the stock one holds.
Old Apr 25, 2007 | 11:13 AM
lsturboswap's Avatar
MAYBE YOUR DIPSTICK ISNT LONG ENOUGH
Old Apr 25, 2007 | 11:17 AM
B16b-EJ8's Avatar
Default Re: quick oil change question. (lsturboswap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsturboswap &raquo;</TD></TR><TR><TD CLASS="quote">MAYBE YOUR DIPSTICK ISNT LONG ENOUGH</TD></TR></TABLE>
Good point, another reason to check specs on the pan.
Old Apr 27, 2007 | 09:55 AM
yeah ive found a couple threads about people using 5 quart moroso oil pans and they are unsure if they should put 4.25 quarts or 5. there was a lot of mixed and unsure answers.
ballisticej1
13
Jun 14, 2009 08:50 AM
vladd
Mar 26, 2009 11:35 AM
Fook_me_honda
Oct 15, 2006 10:10 PM
hondaboy4life
Sep 29, 2006 08:01 AM
speedy108
Jun 30, 2004 06:56 AM
