Idle Problem in my EK
Old Apr 24, 2007 | 07:53 PM
GetSmoked's Avatar
Default Idle Problem in my EK
I have a b20b with an odb1 conversion running on a 92 LS ECU. At first, the idle would bounce from 800 to the point where it would almost die out. Then the check engine light came on. After about a week or so my idle stopped bouncing but it now idles at 2-3.5k depending if my car is warmed up. When i engage the clutch to when the car starts to move the idle is normal for that 2 seconds that it catches gear. But once i put it in neutral the idle is back at 2k. I just checked the check engine light and its 41 Primary oxygen sensor heater. I dont know what that has to do with my idle problem. Any feedback would be good. Thanks.
Old Apr 25, 2007 | 12:04 PM
GetSmoked's Avatar
Default Re: Idle Problem in my EK (GetSmoked)
bump
Old Apr 25, 2007 | 12:17 PM
97Ej6mike's Avatar
Your IACv is not functioning correctly, and either needs to be cleaned out or replaced as a whole.
Old Apr 25, 2007 | 05:42 PM
GetSmoked's Avatar
Default Re: (97Ej6mike)
iacv was not the problem. bump
Nisif
Nov 26, 2011 07:22 PM
DO/\/\O
14
May 9, 2011 05:56 PM
jecho2006
Jul 8, 2008 05:38 AM
GreenMachineRex
Sep 22, 2005 03:12 PM
nevin
Dec 10, 2004 03:04 PM
