Idle fluctuation problem
Old Dec 10, 2004 | 12:42 PM
nevin's Avatar
Default Idle fluctuation problem
The motor is an obd0 b18a and it revs on its own from idle to 3k rpm all the time even in gear which makes the car very difficult to drive.
If I put my finger over the hole right before the throttle plate the idle returns to normal.
I was planning on getting a new tb but im not sure if thats the problem.
How do I fix this?
Old Dec 10, 2004 | 03:04 PM
IVI's Avatar
IVI
Default Re: Idle fluctuation problem (nevin)
look into iacv or fitv.
i believe the top whole is the iacv, bottom hole fitv.
does it stop when the car warms up?
are you getting a check engine light?
unplug the connector for the iacv, what happens?
Nisif
Nov 26, 2011 07:22 PM
ddubtoille
Aug 13, 2008 02:39 PM
nevin
Dec 12, 2004 11:52 AM
TheIntegraGuy
Jan 22, 2004 06:48 PM
