V-Tec problem...please help!
Old Apr 24, 2007 | 06:50 PM
DC2_ITR's Avatar
Default V-Tec problem...please help!
Hello, im a Type R newbie...i just got my R a few weeks ago...the car is mint only 55k on the motor, and its a 98...bone stock.
Anyways the v-tec has been working fine...but then today i noticed something...basically the v-tec kicks in where it is supposed to however you can barely hear it or feel it...i can tell its there however its ALOT quieter than it used to be and i dont feel as much of a pull when it kicks in...
I dont understand what the problem could be...i did a oil change last week and i checked my oil tonight...there actually seems to be TOO MUCH oil in there...could that be the problem?
Any ideas guys...?
Thanks
Old Apr 24, 2007 | 07:07 PM
cltitus's Avatar
your finally used to it so you wont notice it as bad as when you first got it
Old Apr 24, 2007 | 08:16 PM
doood's Avatar
been there done that
Default Re: (cltitus)
you need a ported vtech solenoid
Old Apr 24, 2007 | 09:39 PM
dk127's Avatar
Default Re: (doood)
too much oil isn't good, but just to make sure, did you check the oil on a level surface with the engine off for at least 5 minutes?
Old Apr 25, 2007 | 03:53 AM
all_motaUSA's Avatar
there is a screen/filter inside the VTEC solenoid. IF this becomes clogged it can cause a problem with the engagement of vtec .........
Old Apr 25, 2007 | 04:35 AM
DC2_ITR's Avatar
Default Re: (dk127)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dk127 &raquo;</TD></TR><TR><TD CLASS="quote">too much oil isn't good, but just to make sure, did you check the oil on a level surface with the engine off for at least 5 minutes?</TD></TR></TABLE>
yes i did...
i guess i should drain some of that oil...
Old Apr 25, 2007 | 04:36 AM
DC2_ITR's Avatar
Default Re: (all_motaUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all_motaUSA &raquo;</TD></TR><TR><TD CLASS="quote">there is a screen/filter inside the VTEC solenoid. IF this becomes clogged it can cause a problem with the engagement of vtec .........</TD></TR></TABLE>
how can it become clogged?
Old Apr 25, 2007 | 04:37 AM
98 ITR's Avatar
That motor takes 4L of oil. Not a drop more. I don't even need to check it anymore. 4L and you're good. How much did you put in???
Old Apr 25, 2007 | 04:53 AM
Default Re: (DC2_ITR)
well since oil circulates throught the solenoid, the purpose of the screen is to keep dirt and particles from going through the solenoid..and eventually, with all the dirt building up on the screen, it might clog up a bit and not let the proper amount of oil circulate through
Old Apr 25, 2007 | 06:07 AM
DC2_ITR's Avatar
Default Re: (98 ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 ITR &raquo;</TD></TR><TR><TD CLASS="quote">That motor takes 4L of oil. Not a drop more. I don't even need to check it anymore. 4L and you're good. How much did you put in???</TD></TR></TABLE>
i dont know how much my mechanic put in...but all i know is its "over" where it is supposed to be on the dip stick
Old Apr 25, 2007 | 07:06 AM
andyt's Avatar
4L is correct (4.2 quarts) after oil change with filter.
However, it calls for 4.8L after overhaul, so I would imagine that unless your guy added a couple quarts too much that its probably ok. Hows your air filter look?
Old Apr 25, 2007 | 08:25 AM
DC2_ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all_motaUSA &raquo;</TD></TR><TR><TD CLASS="quote">well since oil circulates throught the solenoid, the purpose of the screen is to keep dirt and particles from going through the solenoid..and eventually, with all the dirt building up on the screen, it might clog up a bit and not let the proper amount of oil circulate through</TD></TR></TABLE>
well my car has been sitting outside for 4 hours now...so i went to check the oil again and there is definetly too much in there...its almot a centimeter over the limit on the dip stick...
could TOO much oil have anything to do with the v-tec not working properly?
also...how do i check the screen in the v-tec silenoid, is it hard to open it up? sorry for all the noob questions...but im...well...a noob
Old Apr 26, 2007 | 01:31 PM
you can pull the vtec solenoid off by the 3 10mm bolts that attach it to the head..as soon as you take it off..VOILA!! its right there
Old Apr 26, 2007 | 09:55 PM
WickedKP's Avatar
Default Re: V-Tec problem...please help! (DC2_ITR)
Well if you every find out what the problem could you post the fix cause i feel the same way too. Just dosen't feel the same anymore.
Old Apr 26, 2007 | 10:49 PM
tartje's Avatar
Default Re: V-Tec problem...please help! (WickedKP)
when some people have this problem its because the matrix of the cat is screwed/partially screwed and its created a block for the exhaust gas
i know its a remote possibility but its worth checking out before you start pulling your engine apart
Old Apr 27, 2007 | 07:27 AM
WickedKP's Avatar
Default Re: V-Tec problem...please help! (tartje)
U know ur probley right. cause i know that happened to some people and that was the last thing ever checked. Damn i don't feel like crawing under the car to remove cat.
Old Apr 27, 2007 | 08:01 AM
itr1244's Avatar
yeah too much oil is worse than having a little less oil
Old Apr 27, 2007 | 12:55 PM
Yelorunnin-R's Avatar
TOO MUCH OIL IS THE PROBLEM, BEFORE U CHECK UR OIL RUN YOUR CAR AROUND THE BLOCK UNTIL WARM AND THEN LET IT CHILL AND THEN CHECK OIL.
blkcivic310
10
Feb 3, 2010 11:47 AM
BDM
Oct 20, 2009 09:02 AM
tigasin
Nov 14, 2008 11:58 PM
h22a1_julien
Aug 27, 2007 01:44 PM
andysila
Apr 17, 2005 11:24 AM
