changed oil then no vtec
Like the title says I helped a friend change his oil then the next day vtec stopped working so wondering what are the steps to trouble shooting my problem its a gsr with type r cams
Thanx HT
Thanx HT
Re: changed oil then no vtec
Basically it. The filter screen gets clogged after years of life. Could be a coincidence but pull it clean it if not get a new gasket. Also check that the solenoid works and isn't frozen.
idunno he said he barrowed a friends wit working vtec im gonna investigate that today when i look at it but im no pro mech lol so im trying to get all options of what i can do to help a friend
This guy is correct. When you take the whole solenoid off you can seperate it into another 2 parts. The filter/gasket will be part of the whole thing where it bolts up to the motor. And on the smaller part that you can take off there will be a little button looking thing. Make sure that can be pressed in pretty easy. Oh and like sleeper said you might want to check your vtec fluid.
