inner tie rod?
Old Apr 24, 2007 | 11:02 AM
94eh2's Avatar
Default inner tie rod?
ok i went to get an alignment the other day and they said they could not align it because i have bad tie rods therefore voiding the warrenty.. i have searched for hours found some helpful threads but none that will help me fully accomplish the job can anyone give me some step by step methods to change the inner tie rod? without taking off the steering rack completely? pictures anything would be helpful..i also know there is a special tool can someone give me a link or pic of what it looks like? thanks
Old Apr 24, 2007 | 01:04 PM
94eh2's Avatar
Default Re: inner tie rod? (305accord)
up
Old Apr 24, 2007 | 02:30 PM
Mr.EM1_EK's Avatar
http://www.mytoolstore.com/astro/asthan14.html
thats what it looks like. it is fairly easy take off the outer tie rod. remove the boot by taking the clamp off the inside. take a look at where the tie rod is connected on the rack and make sure there is no pin holding it. place the right adapter on the tool, slide it over the inner tie rod and turn it off. might be a little tuff so make sure you have a breaker bar. might want to put some lock-tite on when installing it. thats what i do at work but it is up to you. good luck
Old Apr 24, 2007 | 08:04 PM
94eh2's Avatar
Default Re: inner tie rod? (Mr.EM1_EK)
thanks anyone else?
skhell
Suspension & Brakes
Apr 16, 2016 10:45 PM
bob78cvcc
Honda CR-V & Element
Dec 10, 2012 01:46 PM
skipbudlong
31
May 6, 2010 10:21 AM
project-boosteD
Sep 14, 2008 09:26 AM
SpoonFedHatch
Suspension & Brakes
Apr 3, 2005 09:26 AM
