Need help with brakes for 91 CRX SI
Old Apr 24, 2007 | 10:34 AM
vvtli78k's Avatar
Default Need help with brakes for 91 CRX SI
i was driving around town at 35mph, went over a pretty hard bump, and next thing my brake pedal is gone very hard, and i have basically no brakes.
some wierd ****, has this happened to any body?
any thoughts?
Old Apr 24, 2007 | 10:36 AM
EL Vap133's Avatar
Default Re: Need help with brakes for 91 CRX SI (vvtli78k)
Take off the wheels and inspect the brake system.
Old Apr 24, 2007 | 10:37 AM
vvtli78k's Avatar
Default Re: Need help with brakes for 91 CRX SI (EL Vap133)
what am i looking for?
seized caliper?
the car is driving fine
brake fluid?
Old Apr 24, 2007 | 10:42 AM
vvtli78k's Avatar
anybody?
Old Apr 24, 2007 | 10:46 AM
mahatma's Avatar
check vacuum lines at the booster!!
Old Apr 24, 2007 | 10:49 AM
haroldthefly91crx's Avatar
if the brakes work but you have to "stand" on the peddle to slow down, check the vacume hose that goes from the intake manifold to the brake booster, if everything is connected, there is a plastic valve in the vacume line, you will see it, take it off and blow into it from both ends, air should only be alloud through in one direction, if it goes through both ways, replace it.
i dont know if a hard bump would cause this but, a vacume leak from that hose will cause a hard peddle
Old Apr 24, 2007 | 12:53 PM
vvtli78k's Avatar
Default Re: Need help with brakes for 91 CRX SI (haroldthefly91crx)
i still have to check that valve, what is that valve called?
initially i did pull the hose of the booster while the car was running, and there was vacuum
also i drove it back home slowly, with my hand on the hand brake and WHENEVER i pressed on the brake pedal to slow down , there is hissing vacuum leak noise, and th epedal goes down very slowly while slowing down
Old Apr 24, 2007 | 01:05 PM
ILcrxsi1's Avatar
I tell doctors what to do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vvtli78k &raquo;</TD></TR><TR><TD CLASS="quote">i still have to check that valve, what is that valve called?
also i drove it back home slowly, with my hand on the hand brake and WHENEVER i pressed on the brake pedal to slow down , there is hissing vacuum leak noise, and th epedal goes down very slowly while slowing down</TD></TR></TABLE>It's something wrong with the booster. Check your vaccum lines.
Old Apr 24, 2007 | 01:14 PM
Ubertec's Avatar
Your booster has a internal vacuum leak the hissing is the vacuum thats supossed to be asstisting the brakes.
Old Apr 24, 2007 | 01:39 PM
vvtli78k's Avatar
Default Re: Need help with brakes for 91 CRX SI (Ubertec)
is that internal leak fixable?
Old Apr 24, 2007 | 02:45 PM
Ubertec's Avatar
You'll have to replace the booster. The diaphram probably got wet with brake fluid ,more than likely you'll have to replace the master cylinder too 1)because it's bypassing fluid(you said it went slowly to the floor) and 2) because it will leak into the new booster and ruin that one.
Old Apr 25, 2007 | 05:00 AM
vvtli78k's Avatar
how easy or difficult is it to change the booster. i have done mechanical work before.
anything to look out for?
any dos or don'ts?
should i go for aftermarket booster like centric or go dealer part or used salvage yard part
i found one on ebay
http://cgi.ebay.com/ebaymotors...ZWDVW
Old Apr 25, 2007 | 08:14 AM
mahatma's Avatar
honestly it's a pain in the dick to get to the mounting bolts. they're way up under the dash against the firewall
since you're replacing it, i'd go ahead and upgrade to 90-93 integra booster & mc....if you have any aspirations for bigger brakes in the future?
Old Apr 25, 2007 | 08:33 AM
vvtli78k's Avatar
Default Re: Need help with brakes for 91 CRX SI (mahatma)
no aspiration as such to upgrade in the future, tryin to keep the car as stock as possible
Old Apr 25, 2007 | 08:36 AM
vvtli78k's Avatar
any write up aboit it hee on h-tech as to how to change the booster. i have figured that the mounting bolts are a pain, but i am determined to doit, as lond as my hands can get to it , i am doin it
Old Apr 26, 2007 | 09:21 AM
vvtli78k's Avatar
to whoever had done this and some thing to think about.
are the 4 booster bolts which are a PIA behind the gauge cluster by any chance, i have this EM11 cluster sitting around and i was thinking about swapping it also.
just a thought
PhatFactory
35
Oct 23, 2009 06:09 PM
Markb16a
Jul 21, 2007 07:18 PM
djnikko
Nov 5, 2004 08:02 AM
Ballade
Aug 10, 2004 04:23 AM
