vtec not working!!!!!
Old Apr 23, 2007 | 08:53 PM
skUnK2jdm's Avatar
Default vtec not working!!!!!
i have a 94 honda hatch dx and i ran vtec to comp and it not working! i have a b18c1 and iam running a p72 and i wired perfect its just not working! the speedometer is not working either could this be the problem?
Old Apr 23, 2007 | 09:16 PM
whit3's Avatar
vss. vtec is engaged by several differnt sensors. Vehicle Speed Sensor is one. poor some water over the tranny and then wiggle the connection of your ss. on top of tranny below throttle body. then start and drive your car to see if it will work. sometimes the water will give correct connection. or like 120 at honda acura its like 160
hope this helps any gl
just my two pennies
Old Apr 23, 2007 | 09:27 PM
95Bubble's Avatar
Default Re: vtec not working!!!!! (skUnK2jdm)
deff. a VSS thing once you get the VSS going you will be rippin massive VTAC in 3rd gear only hahaha seriously yeah vtec will work FYI vtec uses vss, oil press im not sure if there is sometihng else but those are two senors that need to be in working order for vtec to hit
skUnK2jdm's Avatar
Default Re: (whit3)
ok so most likely its the speed sensor because my mph isnt working,right?
Old Apr 24, 2007 | 09:47 AM
skUnK2jdm's Avatar
Default Re: (skUnK2jdm)
how do you check if its the speed sensor? or the wiring because my car use to be auto!
Old Apr 24, 2007 | 04:22 PM
95Bubble's Avatar
get a dvom(multimeter) get the wiring diagram for your car, check the ohms on your vss than you can check ohms in the wiring going to your ecu from the vss..... that list of cars im going to assum you didnt build??
Old Apr 24, 2007 | 07:45 PM
STI champstar's Avatar
Default Re: (95Bubble)
swap a good part for a bad part. find someone with an integra n ask to borrow theirs. =P
stehigs321
15
Mar 1, 2019 05:16 PM
young geezer
May 21, 2009 06:20 PM
ricearoni56
Feb 8, 2008 09:31 AM
HONDRETTI
Nov 20, 2007 10:20 AM
EKhothatch
Sep 2, 2005 09:08 AM
