Honda S2000 Honda S2000
squeaking/creeking noise
Old Apr 21, 2007 | 06:52 PM
b20integrapower's Avatar
Default squeaking/creeking noise
everytime i get going in first gear, i get a squeaking/creeking noise form the left rear. it also happens on little bumps if im going slow. Im hoping it isn't the axles, or diff. Could it possible be my springS? im lowered on tein s-techs. ty guys.
Old Apr 21, 2007 | 09:19 PM
LAS2K's Avatar
Default Re: squeaking/creeking noise (b20integrapower)
wheel bearing?
Old Apr 21, 2007 | 10:47 PM
Default Re: squeaking/creeking noise (LAS2K)
****. didnt think of that. maybe that's what it is. How do i confirm?
Old Apr 21, 2007 | 11:06 PM
Mr. Projekt's Avatar
* B A N N E D *
Have someone help you bounce your car. Maybe the springs unseated.
Make a couple tight left and right circles in the car slowly, and listen for wheel bearing squeaks.
Old Apr 21, 2007 | 11:32 PM
fish22's Avatar
if your going over bumps and hearing it, i doubt it would be a wheel bearing. though, creaking sounds would indicate a failed hub/bearing, it would occur when certian torque would be applied(acceleration, reverse), or on highway speeds where the bearings get pretty warm. i'm guessing this has to do with a spring or suspension part.
Old Apr 21, 2007 | 11:56 PM
Default Re: squeaking/creeking noise (fish22)
thanks guys. ill try that out dang. ty =D
dang knows how expletive my car is...
Old Apr 22, 2007 | 06:48 AM
Otherguy's Avatar
NASIOC.com
This is what my car is doing, but only when I'm shifting or letting off the gas when in gear
Old Apr 22, 2007 | 08:37 AM
slammed_s2k's Avatar
Default Re: squeaking/creeking noise (Otherguy)
bushings could be the problem too?
Old Apr 22, 2007 | 09:00 AM
Otherguy's Avatar
NASIOC.com
Default Re: squeaking/creeking noise (slammed_s2k)
I dont know, Im about to go under the car and inspect it... *sigh*
Old Apr 22, 2007 | 09:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Otherguy &raquo;</TD></TR><TR><TD CLASS="quote">I dont know, Im about to go under the car and inspect it... *sigh*</TD></TR></TABLE>
i gotta do the same today. we'll see what i find.
Old Apr 22, 2007 | 09:53 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Otherguy &raquo;</TD></TR><TR><TD CLASS="quote">This is what my car is doing, but only when I'm shifting or letting off the gas when in gear</TD></TR></TABLE>
Ruled out clutch buzz?
Old Apr 22, 2007 | 12:10 PM
Otherguy's Avatar
NASIOC.com
Default Re: squeaking/creeking noise (Mr. Projekt)
yes sir, it more a less a clicking
Old Apr 22, 2007 | 02:30 PM
* B A N N E D *
Tighten axle nuts?
Old Apr 22, 2007 | 09:38 PM
hey dang, if i buy those springs, could u help me install? or do you have a shop that'll do it? ill buy u beer
gotta use your id though
Old Apr 22, 2007 | 09:41 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower &raquo;</TD></TR><TR><TD CLASS="quote">hey dang, if i buy those springs, could u help me install? or do you have a shop that'll do it? ill buy u beer
gotta use your id though </TD></TR></TABLE>
tie rod ends
balljoint
loose subframe bolt
mine was from a busted balljoint and loose subframe bolt, it was not moving by hand but you get a wrench on that thing and you'll know it's not torqued down.
i never found out why even after checking all the axle, axle nuts, brake, etc.
then i gotten myself a x brace=hammer on the nail
Old Apr 22, 2007 | 09:49 PM
WowOzYouRock's Avatar
Default Re: squeaking/creeking noise (iam7head)
you guys are thinking extreme... b20integrapower, check your exhaust if its hitting anything... just move it around... prolly hitting on rear lower brace..
Old Apr 22, 2007 | 09:54 PM
Default Re: squeaking/creeking noise (FR-MOB: Jerk)
one more thing, make sure the upper strut nuts are tight...
Old Apr 22, 2007 | 11:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Jerk &raquo;</TD></TR><TR><TD CLASS="quote">one more thing, make sure the upper strut nuts are tight... </TD></TR></TABLE>
i think you figured my problem out. that makes the most sense for the noise im hearing.
lurice01
19
Sep 12, 2023 04:27 PM
RA61825
May 9, 2007 12:10 PM
PAID-$$$
Jun 30, 2004 09:12 AM
