brake noise...
Old Apr 20, 2007 | 10:55 AM
minime92's Avatar
New User
Default brake noise...
Ok...yesterday i had new cv axles, rotors and brake pads installed but the problem is its making a almost grinding noise or rubbing against something. I've talked to other people but they tell me that maybe the rotors are just adjusting with the new brake pads. Or the dust shield could be rubbing against the rotors. What should i do?
Old Apr 20, 2007 | 11:14 AM
SkertySkerty's Avatar
hahaha yes first off its a completely new brake system basically the brakes will squeek a little until the brake in. BUT theres more Just jack the car up take the wheels off make sure the dust sheild isnt hitting the rotor because there right it could be bent onto the rotor so check all 4 unless you only have front disk then just check the front der so yeah and if they are bent just push them back
ndogg810
Honda Civic (2001 - 2005)
Jan 9, 2007 07:10 PM
Built_Fast
Jun 26, 2005 10:28 AM
lo0nY
11
Feb 20, 2005 10:57 PM
93egSIboi
Feb 1, 2005 04:51 PM
JICsube
Oct 3, 2002 08:31 PM
