brake noise...
New User
brake noise...
Ok...yesterday i had new cv axles, rotors and brake pads installed but the problem is its making a almost grinding noise or rubbing against something. I've talked to other people but they tell me that maybe the rotors are just adjusting with the new brake pads. Or the dust shield could be rubbing against the rotors. What should i do?
hahaha yes first off its a completely new brake system basically the brakes will squeek a little until the brake in. BUT theres more Just jack the car up take the wheels off make sure the dust sheild isnt hitting the rotor because there right it could be bent onto the rotor so check all 4 unless you only have front disk then just check the front der so yeah and if they are bent just push them back
ndogg810
Honda Civic (2001 - 2005)
01-09-2007 07:10 PM
