Whats the best way to hook up vacum lines!!!
Old Apr 19, 2007 | 06:13 PM
boostedteg4dr's Avatar
Default Whats the best way to hook up vacum lines!!!
How should I hook up my waste gate, boost controller, and blow off valve? My waste gate and boost controller is hooked up to the turbos compressor outlet with a T. The other end of the boost controller is hooded up to the top of the waste gate. My blow off valve is hooked up to my intake manifold. Is this the best way to do it?
Old Apr 19, 2007 | 06:21 PM
oranginal's Avatar
Default Re: Whats the best way to hook up vacum lines!!! (boostedteg4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedteg4dr &raquo;</TD></TR><TR><TD CLASS="quote">How should I hook up my waste gate, boost controller, and blow off valve? My waste gate and boost controller is hooked up to the turbos compressor outlet with a T. The other end of the boost controller is hooded up to the top of the waste gate. My blow off valve is hooked up to my intake manifold. Is this the best way to do it? </TD></TR></TABLE>
Definitely not "the best way". . .
i think the best way might be to get a vacuum manifold, like the one from golden eagle, and install it using a big T at the brake booster and hook up everything to that.
I think i am going to run the waste gate off of the compressor, and T into the brake booster and use another T for the boost controller and BOV.
hope this helps
Old Apr 19, 2007 | 07:31 PM
Default Re: Whats the best way to hook up vacum lines!!! (oranginal)
I have enough vacuum fitting on my intake manifold. It is a victor x. The reason I have it hooked up the way I do is so I don’t have to run a vacuum hose from boost controller relay that is at the front of the engine all the way back to the intake manifold. Is simply hooks up to the turbo outlet with a 6 inch hose. The hose is then teed to the side of the waste gate and the top of the waste gate is hooked to the other end of the boost controller relay.
I was just curious how to hook it up because I know the pressure there is higher then in the intake and I have heard that when Vtec hits the manifold pressure drops 1-2 psi and the climbs back up. I was thinking it would climb faster if the boost controller and waste gate were hooked to the intake manifold.
Old Apr 19, 2007 | 08:00 PM
BlackBeastEK's Avatar
just grab a vacuum manifold and T off your brake booster then boom you got a **** load of vacuum lines to run
Old Apr 20, 2007 | 01:14 AM
RC000E's Avatar
Default Re: (elementb16a)
I gotta plug these dudes....they are sponsors on here. I just ordered one of their vacuum manifolds yesterday...AWESOME deal too. So damn cheap, even with the brass fitting kit, which is what I got.
Dude on the phone said he still had alot, and even though the thread is locked, he sold it to me for the price listed. Grab one man.
https://honda-tech.com/zerothread/1657556
Old Apr 20, 2007 | 10:53 AM
thats the same one i have very nice and real good price
91crxturbo
Sep 25, 2006 11:31 AM
RTW DC2R
May 19, 2006 04:42 AM
Patron
Jul 23, 2004 07:02 AM
buckfittyone
Jul 31, 2003 05:35 PM
bruthaboost
Nov 4, 2002 04:15 PM
