D16Z6 Civic Coupe Auto Tranny, Racecar
What can be done to this dirt car to make as much power as possible to last maybe 10 races max (10 laps) motor must remain stock. Only ecu work can be done, how high can we change the rev limiter to? Any ideas welcomed. This also has an auto tranny.
Nothing if you have to leave it stock. Your not going to gain any power by raising the rev limiter, just blow up the engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageAlchemist »</TD></TR><TR><TD CLASS="quote">sounds like a waste of time, esp with a civic. </TD></TR></TABLE>
It's not a waste of time when its for fun, and its actually going to be raced... unlike 98% of the **** out there...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by byronl »</TD></TR><TR><TD CLASS="quote">auto-to-manual swap allowed? that would help big time.</TD></TR></TABLE>
Yes it's allowed but its a bit more work than what this guy is willing to do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">How much time and money are you willing to invest, and what are the specific modifications allowed?</TD></TR></TABLE>
Very little money... Exhaust manifold, intake manifold cannot be changed. CAI is allowed. Exhaust system is chopped off at the end of the header...
Thinking of increasing the fuel pressure and running larger injectors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2392si »</TD></TR><TR><TD CLASS="quote">Nothing if you have to leave it stock. Your not going to gain any power by raising the rev limiter, just blow up the engine. </TD></TR></TABLE>
What about changing the shift points? Blowing it up isnt too much of a concern as long as it lasts 10-15 runs... or roughly 25-40 miles of actual driving.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CptCorN »</TD></TR><TR><TD CLASS="quote">Thinking of increasing the fuel pressure and running larger injectors.</TD></TR></TABLE>
That really won't benefit you on a stock motor. If you are essentially only allowed to modify the ECU, your best bet would be to chip it and tune with an application such as Uberdata or Crome.
considering its going to be a dirt racer then just tune it so that it works best at peak torque at the RPM that it would benefit you the most.
