rattle @ shifter
Old Apr 19, 2007 | 07:35 AM
JLEK's Avatar
Default rattle @ shifter
hey guys i just got a LS integra.. and when im driving around the car makes a rattling sound at the shifter area. when i put pressure to the side the rattle goes away. does anybody have a hypothesis on the cause?
Old Apr 19, 2007 | 07:40 AM
mac_24_seven's Avatar
Default Re: rattle @ shifter (emperor9)
Maybe a heat shield rattling? Have you looked under your car yet?
Old Apr 19, 2007 | 07:49 AM
sickofitall1113's Avatar
yep heat shield probably. rip that sucker out and you should be fine
Old Apr 19, 2007 | 08:29 AM
JLEK's Avatar
Default Re: (sickofitall1113)
heatshield rattle will stop when i put pressure on the shift by pushing the shift **** to the side?
Old Apr 19, 2007 | 08:39 AM
forumnoobie's Avatar
I have the exact same problem, I always put a heavy object next to the shifter when im cruising. It doesn't sound like its from under the car though. I am just to lazy to see whats loose.
Old Apr 19, 2007 | 08:44 AM
JLEK's Avatar
Default Re: rattle @ shifter (forumnoobie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forumnoobie &raquo;</TD></TR><TR><TD CLASS="quote">I have the exact same problem, I always put a heavy object next to the shifter when im cruising. It doesn't sound like its from under the car though. I am just to lazy to see whats loose.</TD></TR></TABLE>
you seriously? could it be that the shifter is loose?
Old Apr 19, 2007 | 08:45 AM
tomithy's Avatar
When mine rattled I checked underneath and one of the bolts came loose. It rattled and moved side to side.
Old Apr 19, 2007 | 08:47 AM
Default Re: (tomithy)
Is it a pain to check underneath? like you can't just pull off the shifter boot can you?
Old Apr 19, 2007 | 08:54 AM
redGSRguy's Avatar
Try tightening the bolt that holds the shifter to the shifter fork thing.
Old Apr 19, 2007 | 09:14 AM
dc4_wHORE's Avatar
Soldering Iron Wizardry
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickofitall1113 &raquo;</TD></TR><TR><TD CLASS="quote">yep heat shield probably. rip that sucker out and you should be fine</TD></TR></TABLE>
Old Apr 19, 2007 | 10:08 AM
bamateg94's Avatar
I have the same exact problem. Mine started rattling when I switched to the B&M shifter. When I took the stock shifter out, I ripped the rubber boot at the base and I didnt replace it.....so in your case, take out the center console and check the rubber boots. It would be a good idea to check the bolts from the bottom to be safe. Ive driven mine for about 10k miles w/ the rattling and it hasnt got worse, I'm just used to it now.
shortyz21
Jun 20, 2011 09:42 AM
Extreez
Dec 13, 2007 08:09 PM
Libertariat
12
Nov 22, 2006 05:56 AM
blackjdmEKcivic
Feb 25, 2005 01:52 PM
aeon
Jun 7, 2004 09:16 PM
