Shifter noise
Ek Forever y0!
Shifter noise
When cruising I've noticed a buzzing sound from my shifter. It's been going on for a while but it's now just annoying. It sounds like there's something in the threads of my shifter vibrating around.
I'm sure it's some cheapo ebay shifter because it was on the car when i bought it. I'm sure it's aluminum as well because it does get pretty hot when I do a lot of driving.
Re: Shifter noise (SLOW guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLOW guy »</TD></TR><TR><TD CLASS="quote">the short shifter is hitting the exhuast pipe there for its gets hot and may vibrate also. i had that problem.</TD></TR></TABLE>
yup wat he said....take it to a muffler shop and get the pipe bent or something thats wat i did
It could be what they have said also i had the same thing and it turned out the bolt connecting the linkage to the shifter was loose causing a really annoying vibration sound.
Ek Forever y0!
Re: (B16b-EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 »</TD></TR><TR><TD CLASS="quote">It could be what they have said also i had the same thing and it turned out the bolt connecting the linkage to the shifter was loose causing a really annoying vibration sound.</TD></TR></TABLE>
I think it's that one. Because I'm 95% positive it's not hitting the exhaust.
How do I got about fixing that bolt?
Ek Forever y0!
Re: (ek forever guy)
Actually it sounds like it's inside the shift ****, but I drove with it off cruising and it was still there. Like it's in the threads.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">Actually it sounds like it's inside the shift ****, but I drove with it off cruising and it was still there. Like it's in the threads.</TD></TR></TABLE> the shifter is vibrating...probably just because its loose.
-Steve
-Steve
Dude i did the same thing...your going to have to jack up your car and tighten the bolt right where the linkage connects to the shifter.
Re: Shifter noise (ek forever guy)
let me know if you fixed it yet ;X, I'm having the same problem with my ebay integra shifter... it's gets even better, when i put it in neutral, the damn thing squeks really bad cause it's rubbing onto the exhaust pipe...
Re: Shifter noise (chineseflyrice)
instead of asking why your shifter is vibrating and you to freaking lazy to jack up the car and tighten it. just DO IT. and you shifter is a solid piece of metal so its not vibrating inside it. just tighten up all the bolts and if it dosent work deal with it.
Re: Shifter noise (SOHC_EK)
I have the same problem with mine I tightend that bolt and it still vibrates Im starting to think its on the other end of the linkage at the transmission
Delano5050
10
02-25-2008 03:27 PM
Delano5050
11
08-20-2007 12:40 PM
