built block side to side movement in rods normal
Old Apr 18, 2007 | 03:40 PM
b18sihatch's Avatar
Default built block side to side movement in rods normal
i was wondering if side to side movement in a built block is normal?
Old Apr 18, 2007 | 03:47 PM
b18sihatch's Avatar
Default Re: built block side to side movement in rods normal (b18sihatch)
side to side movement in piston rods
Old Apr 18, 2007 | 04:13 PM
SD_Lurker's Avatar
HT White Ops
I have seen very minimal movement of the rods. How bad is it? .01mm side to side?
Old Apr 18, 2007 | 04:14 PM
SD_Lurker's Avatar
HT White Ops
Default Re: built block side to side movement in rods normal (SD_Lurker)
Your talking about where the rod meets the crank or the piston?
Old Apr 18, 2007 | 04:28 PM
EK FLY's Avatar
is normal if the rod moves from side to side ( t-belt to tranny side's ) is completly normal , however its not normal when the rod move forward nad backward
Old Apr 18, 2007 | 04:40 PM
b18sihatch's Avatar
Default Re: built block side to side movement in rods normal (super-hatch)
its where the rod connects to the crankshaft, it has slight back and forth motion
Old Apr 18, 2007 | 05:02 PM
NJIN BUILDR's Avatar
It is usually referred to as rod side clearance.Up to about .015" is OK.
Old Apr 18, 2007 | 05:21 PM
90 integra's Avatar
that usally happens when it has spun a bearing. I would have it rechecked for clearances and retorque just to make sure,becuase it seems like it has clearance problems. cheack it and good luck.
Old Apr 18, 2007 | 05:51 PM
SD_Lurker's Avatar
HT White Ops
Default Re: built block side to side movement in rods normal (90 integra)
A spun bearing does not move side to side. The rod will usually move in an up and down motion with a spun bearing. Its normal like I stated before but movement must be very minimal.
Old Apr 18, 2007 | 05:53 PM
b18sihatch's Avatar
block is fresh never used and spings freely
Old Apr 18, 2007 | 05:56 PM
SD_Lurker's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">block is fresh never used and spings freely</TD></TR></TABLE>
Awesome, you should be good to go. Again the movement is very minimal, correct?
Old Apr 18, 2007 | 06:04 PM
b18sihatch's Avatar
yes they all have the same movement so i assume its part of the clearence prefrences. all have the exact same ammount of movement which is minimual
Old Apr 18, 2007 | 06:36 PM
1Bar GSR's Avatar
Crankshaft side it is ok for the rod to move minute amount side to side.
Old Apr 18, 2007 | 06:56 PM
b18sihatch's Avatar
Default Re: built block side to side movement in rods normal (1Bar GSR)
with clearences correct me if im wrong but dont clearences depends on how the motor is going to be used and how much power it will handle. i think i read loose clearences are for high apps or som ething like that..
1320london
Engine Machining & Assembly
Apr 24, 2017 03:27 PM
hybridmiklo
Jan 27, 2012 05:40 PM
iownahatchback
Jan 31, 2010 05:54 PM
NAgsr-teg
May 6, 2006 02:01 PM
B pwr
Oct 30, 2002 11:45 AM
