Backup ECU fuse keeps burning - Help!
Old Apr 18, 2007 | 02:00 PM
MITSU_MaN's Avatar
Default Backup ECU fuse keeps burning - Help!
I just swaped in a new D16z6 into my eg hatch, after throwing a rod in my old one. We got the swap done and everything hooked up, but the car didnt have any spark or fuel.
I was stumped until, i found that the backup fuse for the ecu (the one that resets the ecu if pulled for 10 secs) was burned.
so i tried swapping in a new 7.5a fuse (like it says in the manual) but it sparked and burned the fuse right away. I tried a few more just to be sure, but it did the same thing.
I figured that it was just a short circuit or ground issue, so i checked all the harnesses and wires but couldnt find anything. I even tried unplugging all of the harnesses that came out of the main relay, but the same thing happened...
Has anyone had this issue before? What should i check? What can i do?
any input or suggestions would be appreciated
thanks,
Najeem
Old Apr 18, 2007 | 05:58 PM
MITSU_MaN's Avatar
Default Re: Backup ECU fuse keeps burning - Help! (MITSU_MaN)
Anyone?
Old May 15, 2007 | 03:44 PM
DeltaCharlie2's Avatar
Bump, cause I'm having the exact same issue and it's driving me crazy.
Old May 15, 2007 | 10:42 PM
Default Re: Backup ECU fuse keeps burning - Help! (DeltaCharlie2)
figured it out. There was a wire shorting out for the radio. Two second fix.
Joshb152
Oct 9, 2015 09:10 PM
LOMPSEG
Engine Management and Tuning
Apr 2, 2009 08:52 PM
xASAPx
Sep 12, 2008 04:10 PM
crxdude
16
Jun 5, 2007 05:18 PM
Metal_SOL
Sep 8, 2002 08:31 AM
