Intake manifold design question.
Old Apr 17, 2007 | 07:31 PM
danielm3's Avatar
Default Intake manifold design question.
I have been working on a intake manifold for a 2jzge and I am having some space issues with the hood and because of that the only way it will fit is if the manifold looks like this:
Would having so little space between the top and the runners be a problem?
Thanks guys.
Old Apr 17, 2007 | 09:36 PM
PSI2HI's Avatar
Former Vendor
Default Re: Intake manifold design question. (danielm3)
I assume from your sig your trying to build something for an IS300? Trying to do a stock placement or a GTE style?
Old Apr 17, 2007 | 10:08 PM
a2zturbo
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danielm3 &raquo;</TD></TR><TR><TD CLASS="quote">I have been working on a intake manifold for a 2jzge and I am having some space issues with the hood and because of that the only way it will fit is if the manifold looks like this:
Thanks guys.</TD></TR></TABLE>
Its not that it will cause a problem so to say, but i wouldn't say it ideal unless you take account for this in your runner lengths/diameters.
Old Apr 17, 2007 | 10:14 PM
danielm3's Avatar
Default Re: Intake manifold design question. (PSI2HI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PSI2HI &raquo;</TD></TR><TR><TD CLASS="quote">I assume from your sig your trying to build something for an IS300? Trying to do a stock placement or a GTE style?</TD></TR></TABLE>
Yeah its for an IS300 and I want to make a stock placement style one, since I don't think anyone has really tried it.
Old Apr 17, 2007 | 10:17 PM
danielm3's Avatar
Default Re: Intake manifold design question. (a2zturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a2zturbo &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah it's the damn space issue, it's too damn tight in there. If it helps any the diameters are 2" on all 6 ports (same as stock), and the runners are... id say about 13" or 15" long
Old Apr 18, 2007 | 07:50 AM
.RTErnie's Avatar
Ive had virtual works intake manifolds and looked at them in my hands...as well as veilside Im's.... both kinda suck imo. There port angles are quite steep...which is good, but it doesnt allow for a smooth entrance into teh port. the VW intake manifold has an abrupt runner angle change near the port opening. I would say make your own head flange and make one from scratch...or cut the runners off and go from there
Old Apr 18, 2007 | 09:22 AM
PSI2HI's Avatar
Former Vendor
No ones bothered to try because why would you want to keep stock placement, all it does it extend the IC piping and crowd the turbo.
My IS setup
Old Apr 18, 2007 | 11:01 PM
99_GS-T's Avatar
Just due to inertia, you are best off trying to pull as much air from directly above the runner inlet as possible.
Can you shorten the runner a bit and drop the floor of the plenum down? Sounds like you already have too much runner length anyway, unless you are aiming for a torque peak around 5000 RPM?
Old Apr 19, 2007 | 07:45 AM
danielm3's Avatar
Default Re: (99_GS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99_GS-T &raquo;</TD></TR><TR><TD CLASS="quote">Just due to inertia, you are best off trying to pull as much air from directly above the runner inlet as possible.
Can you shorten the runner a bit and drop the floor of the plenum down? Sounds like you already have too much runner length anyway, unless you are aiming for a torque peak around 5000 RPM?</TD></TR></TABLE>
I can't lower it anymore because there is just no room. I scraped the idea since I can't make it fit. Thanks for the help guys.
Old Apr 20, 2007 | 11:49 AM
CVC9216's Avatar
[QUOTE=PSI2HI]No ones bothered to try because why would you want to keep stock placement, all it does it extend the IC piping and crowd the turbo.
My IS setup
http://www.imperial.org/~sls/Project...jpg[/QUOTE]
what turbo manifold is that?
Old Apr 22, 2007 | 07:39 PM
93LSivic's Avatar
Default Re: Intake manifold design question. (CVC9216)
We build and sell these. Very easy bolt on application. Contact us for more info
Our shops SC sporting it.....you can also peep it in this months (May) issue of Modified mag.
akhlaq768
10
May 7, 2007 03:31 PM
hulk_22
Dec 11, 2006 01:03 PM
spoonsports12
Oct 12, 2005 09:53 AM
HamiltonRex
Oct 6, 2005 06:04 AM
BoOsTeD C1
Jan 5, 2005 09:35 AM
