Oil Drain from turbo to oil pan
Old Apr 17, 2007 | 01:59 AM
civicsaremean's Avatar
Default Oil Drain from turbo to oil pan
everytime i start my car or when i shut it off, the hose from the drain of turbo to oil pand has a small leak and when i touch it, its all oily. im using a steering pump rated at 250 psi. should i use something else?
Old Apr 17, 2007 | 03:21 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Oil Drain from turbo to oil pan (civicsaremean)
What are you talking about a steering pump for?
Sounds like a simple leak to me. What type of hose are fittings are you using?
Old Apr 17, 2007 | 04:34 AM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsaremean &raquo;</TD></TR><TR><TD CLASS="quote">everytime i start my car or when i shut it off, the hose from the drain of turbo to oil pand has a small leak and when i touch it, its all oily. im using a steering pump rated at 250 psi. should i use something else? </TD></TR></TABLE>
Steering pump??
Are you saying your using a pressure hose from a power steering pump as the drain hose? Is the hose the right size? Is oil leaking from the ends or is coming through the hose itself?
Old Apr 17, 2007 | 04:37 PM
josh0407's Avatar
Default Re: Oil Drain from turbo to oil pan (Autoworks)
use stainless steel line
bluebluecivic2
May 23, 2016 03:30 AM
DeDonDeRosa
Dec 10, 2005 10:25 AM
Modify
Oct 12, 2005 03:03 PM
b4tn
Dec 30, 2004 04:00 PM
OKSolSi
May 9, 2002 10:58 PM
