Adjusting headlight projection?
Well I have projector lights on my 98 EX. Have had them for quite a while actually, and I believe the light beam points a bit low so I don't get a full projection on the road in front of me. Just wondering if there was a way to adjust it to where the projection was higher up/farther out. Is it just toying with the headlight bracket (mount underneath) or what?
I have a 5th gen, and on mine, there is a big screw pointing towards the front on the back top of each headlight, turning it to the right I think makes them point higher, and to see if they are even, at night, park faving a wall or something like 4 feet away. I have mine pointinga little higher than stock cause I couldnt see anythign at night.
do you mean ebay projector lights? if it is, its not that its pointing low its because those projectors are literally **** because they arent made of good quality. even if u switched with hids and used those ebay projector headlights, it still wont shine as bright as a stock headlight with halogen bulb
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haiyter »</TD></TR><TR><TD CLASS="quote">do you mean ebay projector lights? if it is, its not that its pointing low its because those projectors are literally **** because they arent made of good quality. even if u switched with hids and used those ebay projector headlights, it still wont shine as bright as a stock headlight with halogen bulb</TD></TR></TABLE>
Very true, but it doesn't help if the halogen projector is aimed too low. There are one or two adjustment screws in the back of the headlight. Clockwise with a socket is up.
I'll have to check my lights and see. The headlights are from Matrixracing.com
Blam -----> http://www.matrixracing.com/p-....aspx
You can see in my car in my avatar...the halo's are on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98savage »</TD></TR><TR><TD CLASS="quote">I'll have to check my lights and see. The headlights are from Matrixracing.com
You can see in my car in my avatar...the halo's are on.</TD></TR></TABLE>
those are the same as ebay projector crap lol
