Decent lug nuts?
Old Apr 16, 2007 | 01:38 PM
WhiteOnRice's Avatar
Default Decent lug nuts?
I don't know what lug nuts I have now but they are seized and I've broken 3 keys trying to get them off (using socket wrench not impact). After I get them off I want to replace them. What lugs are decent. I want at least one to be a locking but don't want an obnoxiously long key. BTW 17" Konig Traffik's not OEM rim.
Old Apr 16, 2007 | 01:43 PM
BlueIntegraBoy's Avatar
Default Re: Decent lug nuts? (WhiteOnRice)
I'm running the black Kyokugen lug nuts.
Spread some anti-seize on your studs before putting on the nuts. (no pun intended )
Old Apr 16, 2007 | 01:51 PM
. a d a m's Avatar
Default Re: Decent lug nuts? (BlueIntegraBoy)
Get some Buddy Club lugs.
Old Apr 16, 2007 | 01:57 PM
About how much are these? (Don't want to spend $100 like Rays)
Old Apr 16, 2007 | 02:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">I'm running the black Kyokugen lug nuts.</TD></TR></TABLE>
I really like the sound of these (7 sided lug). What's the key like? Do you need a socket or just the wrench?
Old Apr 16, 2007 | 02:04 PM
EG2Driver's Avatar
if the lugs are that hard to remove, i think u'll be breaking a few studs. Inspect the threads after you take the lugs off, they may be damaged. If you put anti seize on there, you will not run into this problem again.
Old Apr 16, 2007 | 02:05 PM
Default Re: Decent lug nuts? (DeadEnd9009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 &raquo;</TD></TR><TR><TD CLASS="quote">if the lugs are that hard to remove, i think u'll be breaking a few studs. Inspect the threads after you take the lugs off, they may be damaged. If you put anti seize on there, you will not run into this problem again.</TD></TR></TABLE>
I know this but I don't want to deal with the long keys because I don't have an impact gun.
Old Apr 16, 2007 | 02:07 PM
EG2Driver's Avatar
kyogen (sp) keys are about 10 cm long. Gorilla lug locks is about 4-5cm long
Old Apr 16, 2007 | 02:08 PM
ekb16's Avatar
the last time i had kyokugen lugs nuts, my key got stripped and couldnt take off my wheel..had to jam sockets on each lug nut to remove them
Old Apr 16, 2007 | 03:08 PM
Silvertc's Avatar
Default Re: (ekb16)
Don't get the ebay knock off **** they will strip your studs for sure
Old Apr 16, 2007 | 03:09 PM
EG2Driver's Avatar
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">the last time i had kyokugen lugs nuts, my key got stripped and couldnt take off my wheel..had to jam sockets on each lug nut to remove them</TD></TR></TABLE>
they're only supposed to be torqued to 80 ft/lbs. I never had a problem with them.
Old Apr 16, 2007 | 03:18 PM
Padawan's Avatar
Darth ModerVader
Default Re: (DeadEnd9009)
they're only supposed to be torqued to 80 ft/lbs. I never had a problem with them.</TD></TR></TABLE>
I never had a problem with my Kyokugen's either, though I always torqued them properly and used anti-sieze. There were some early reports of stripped keys, but from what I recall, the newer sets included an improved key that was supposed to be more durable.
Old Apr 16, 2007 | 03:23 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (ekb16)
That's what happens when you overtorque them. I've never had a problem with mine.
Old Apr 16, 2007 | 03:58 PM
ekb16's Avatar
i bought the car and it came with them...while i was driving back home with the car i ran over a nail and the next morning i had to get it repaired so i needed to take off the wheel..took it to the shop and they used an impact gun on it and after that the key was done for..no matter what i tried i couldnt get off the lug nuts so i had to use a bunch of sockets
Old Apr 16, 2007 | 05:46 PM
EG2Driver's Avatar
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">i bought the car and it came with them...while i was driving back home with the car i ran over a nail and the next morning i had to get it repaired so i needed to take off the wheel..took it to the shop and they used an impact gun on it and after that the key was done for..no matter what i tried i couldnt get off the lug nuts so i had to use a bunch of sockets</TD></TR></TABLE>
that shop is stupid. The key is not made to be used with an impact. Its too thin, plus it says not to use the key with an impact on the package, but u didn't have that.
That sucks.
Old Apr 16, 2007 | 06:34 PM
censurebush's Avatar
From: everything for everyone, and nothing for ourselves
bro, any 12x1.5 nut would work. i like the look of a "tuner" nut, open ended, acorn... all of these are CHEAP about twelve bucks in my neck of the woods. don't spend $100 on a set that locks.
Old Apr 16, 2007 | 06:45 PM
EkJavi's Avatar
* B A N N E D *
Default Re: (censurebush)
why dont u try the buddy clubs.. i know a place here in socal that sells them for 72$ firm for all 16
egg_baLLa
Jun 23, 2008 02:53 PM
importboi22
Sep 25, 2006 04:44 PM
INTEGRA_boy
Nov 21, 2005 01:08 PM
Sohc Driver
34
Dec 25, 2002 02:04 PM
