Problems with starting the car and CEL coming on, please help...
Old Apr 16, 2007 | 11:19 AM
lax1089's Avatar
Default Somebody please help me...
97 ex
i have posted on this before and searched countless nights in the archive...still having trouble.
when i start my car it struggles and then idles erratically until i give it gas (which isnt too bad). HOWEVER...sometimes it wont start. the electrical stuff comes on and it clicks but other than that...nothing. also...i keep having to pull out the ecu fuse because it keeps throwing the code "Cylinder 4 Misfire" whenever i start it.
any ideas? is it the starter? IACV?
Old Apr 17, 2007 | 03:45 AM
lax1089's Avatar
Default Re: Somebody please help me... (lax1089)
accompanyinbg the misfire code was a "manufactorer ignition cntrl or clynder misfire" i believe #P1339
Old Apr 17, 2007 | 07:41 AM
BlUAc's Avatar
well first have you done any preventive maintenance on it? Or checked the plugs or tha dizzy cap?
Old Apr 17, 2007 | 08:00 AM
adrift77's Avatar
My 98 lx has a similar problem, although I don't recall the exact code, the cause of it(according to the dealership) is the cam shaft position sensor needs to be replaced. This problem started after a couple of spark plugs fouled on me.
Old Apr 17, 2007 | 09:52 AM
PHAT97EX's Avatar
Pretty much the same happened with my civic. Check your gap on the spark plugs and make sure you have good wires. Bad wires+incorrectly gapped plugs=misfire. Not always the case, but it's what happened to me. Hope this helps.
Old Apr 17, 2007 | 06:12 PM
lax1089's Avatar
Default Re: Somebody please help me... (PHAT97EX)
how do i check the dist. and spark plugs....i havnt messed with either since honda replaced them all about 2 months ago and this problem did not happen right after they were done...so i dont know if that is it
Old Apr 19, 2007 | 03:32 AM
lax1089's Avatar
bump
Old Apr 19, 2007 | 10:54 AM
lax1089's Avatar
bump anyone?
Old Apr 19, 2007 | 11:02 AM
Velocifero's Avatar
it could be your main relay.
defriend2001
Sep 2, 2014 05:29 PM
stangnick
Nov 9, 2009 07:02 PM
Inextricabledrvr
Sep 9, 2009 09:01 PM
TegProject
Mar 4, 2007 06:28 PM
KimChiKid
Aug 10, 2003 05:37 AM
