car dies help!!!
i would be driving in traffic then sometimes when i clutch in the car would die. i see the rpm dropping all the way to zero after i clutch in that is when it dies. if it doesnt die it woul drop to like 200 rpm. what u think the problem is what i need to fix?
Make sure your car didn't jump time on the cam gears. Check ignition system (plugs, wires, cap, rotor, test coil & ignitor) and check ignition timing. Check your valve adjustment, check operation of the dashpot system if present, clean your FITV, IACV, check fuel pressure, and finally check your electrical system, alt. battery, and grounds.
There are ALOT of things that can cause your problem. Good luck.
when im on neutral on a complete stop the the idol is normal. but when i trap on the gas the rpm would go up and when it come down it would drop below the 700-800 rpm the normal idol? what seems to be the problem
