car have problem need help
Old Jun 25, 2007 | 07:01 PM
johnls's Avatar
Default car have problem need help
car stuttering when i accelerate some times it does it before is warmed up no smoke come out the exhaust could it be a bent valve or what lmk know what you guys think thanks
Old Jun 25, 2007 | 07:27 PM
skata89's Avatar
when was the last time you changed your spark plugs??
Old Jun 26, 2007 | 03:09 AM
johnls's Avatar
Default Re: (skata89)
about two months they look good
Old Jun 26, 2007 | 04:53 AM
skata89's Avatar
well turn the car on and take off the oil cap and if you feel air being push out, that means you have blow by. Which is not good.
Old Jun 26, 2007 | 09:12 AM
johnls's Avatar
well i got a new head for it but could the bottom end be messed up to
Old Jun 26, 2007 | 09:35 AM
DeltaCharlie2's Avatar
Default Re: (johnls)
I like to check certain systems together.
I.E. - check everything in the ignition system to make sure your spark is good:
-Check your distributor cap to see if the pickups are still good
-Check the plug wires
-Spark plugs
-Check the timing
-Blah, Blah, Blah
Then start checking all of the components that get fuel to the cylinders... So on and so forth.
Good luck.
j4yzn
Aug 24, 2009 12:45 PM
tree fingers
Aug 4, 2009 11:58 AM
dcsports
Dec 7, 2008 06:54 PM
Westracing33
Oct 20, 2007 10:02 PM
Downz
Feb 11, 2007 06:52 PM
