How to remove cruise control unit from 92 SI? Searched and no luck
As the topic states i wanna remove the factory cruise control circled in the photo above. The cable goes straight back into the firewall. It's already unbolted so i was wondering if i just cut the cable up to the firewall? or there's another way? anyone with experience?
Look under the dash at the gas peddle, you unhook the cable from there then on the firewall turn the black plastic grommet like a 1/2 turn and it pulls out. No need to cut it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE »</TD></TR><TR><TD CLASS="quote">check your pm, that will answer all your questions</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jesimmers »</TD></TR><TR><TD CLASS="quote">Look under the dash at the gas peddle, you unhook the cable from there then on the firewall turn the black plastic grommet like a 1/2 turn and it pulls out. No need to cut it.</TD></TR></TABLE>
Thanks to the both of you
Tmrw i'll check the gas peddle thing out
navin
Dec 16, 2007 10:04 PM
dayaftertomorrow
11
Aug 30, 2005 05:55 AM
