messed up door lock
my driver side door lock is messed up. it makes this machine gun sound when i try to unlock it with the remote or the door switch. it does not make the noise however, when the door is open. another problem is that i cannot fully close the lock manually. i can push it so hard that i feel like its going to break and it still wont move over. the passenger side is perfectly fine.
basically the remote/switch only unlocks it 5% of the time so if i want to get out, i need to roll down the window and use the key to unlock the door. its annoying as hell and everybody looks over like im retarded.
i took the door panel off and sprayed wd40 on everything that i thought might need to be lubed up.
here are some threads that describe the same symptoms.
https://honda-tech.com/zerothread?id=867872
https://honda-tech.com/zerothread?id=1911034
https://honda-tech.com/zerothread?id=1907380
https://honda-tech.com/zerothread?id=1202587
Intercooler
Nov 18, 2004 08:43 PM
