Help: Driver's Side Hard to Lock From Inside
Old Jun 11, 2003 | 02:53 PM
ALF's Avatar
ALF
Default Help: Driver's Side Hard to Lock From Inside
Anyone have this problem before? It's extremely hard to manually lock or unlock the driver's side door. If I use the automatic door switch, it locks and unlocks fine. The passenger's side works normally if locked or unlocked manually.
Old Jun 11, 2003 | 03:07 PM
ebelp's Avatar
Default Re: Help: Driver's Side Hard to Lock From Inside (ALF)
Is it hard to lock when the door is open or closed? If the driver's door is open, you have to lift up on the door handle, then flip the lock on the inside. If the driver's door is closed and you can't manually lock it....take the door panel off and investigate. Maybe you can lube it up?
Old Jun 11, 2003 | 03:17 PM
ALF's Avatar
ALF
Default Re: Help: Driver's Side Hard to Lock From Inside (ebelp)
Yeah, I forgot to mention this is when the door is closed shut.
Old Jun 11, 2003 | 03:19 PM
ebelp's Avatar
In that case, it probably just needs some greazzy lovin'.
nismogrendel
Jan 26, 2013 07:34 PM
William1991b
Jun 26, 2011 04:00 PM
B18Sleeper
11
Nov 1, 2007 06:24 PM
JDMjukie
Mar 12, 2007 08:21 PM
Intercooler
Nov 18, 2004 08:43 PM
