Want to build an ls/vtech
ur gonna get flamed by many ******** on these boards for not searching and getting clown on your spelling and using the word "vtech" but ill b nice.. ur gonna need a vtec head (gsr, b16, or type R) then ur gonna need to get an LSVTEC conversion kit and then a vtec ECU.. those are the basic things u need first.. but honestly.. if ur gonan build an LSVTEC and to make it fast, ur also might consider higher comp pistons which all adds up to boosting.. so y not just boost
Go to this thread it has just about anything you need to know about ls/vtec https://honda-tech.com/zerothread?id=1923227
Please Search Next Time
Thank You
Thank You
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2 VTEC »</TD></TR><TR><TD CLASS="quote">ur gonna get flamed by many ******** on these boards for not searching and getting clown on your spelling and using the word "vtech" but ill b nice.. ur gonna need a vtec head (gsr, b16, or type R) then ur gonna need to get an LSVTEC conversion kit and then a vtec ECU.. those are the basic things u need first.. but honestly.. if ur gonan build an LSVTEC and to make it fast, ur also might consider higher comp pistons which all adds up to boosting.. so y not just boost</TD></TR></TABLE>
how does raising compression add up to boosting?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">
how does raising compression add up to boosting?</TD></TR></TABLE>
dude i said ALL add up.. if u open ur eyes wider and read, buying a vtec head and conversion kit and pistons and all that LSV stuff adds up to boosting his LS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by czer47 »</TD></TR><TR><TD CLASS="quote">would like to know how much one would set me back for the vtech head and the ecu and were I could get both</TD></TR></TABLE>
Parts and labor atleast $1500. Some may tell you otherwise but they will be doing the work in the dirt in there backyard with used parts and think they are cool.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackdelslo »</TD></TR><TR><TD CLASS="quote">Parts and labor atleast $1500. Some may tell you otherwise but they will be doing the work in the dirt in there backyard with used parts and think they are cool.</TD></TR></TABLE>
LOL.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2 VTEC »</TD></TR><TR><TD CLASS="quote">dude i said ALL add up.. if u open ur eyes wider and read, buying a vtec head and conversion kit and pistons and all that LSV stuff adds up to boosting his LS</TD></TR></TABLE>
what you talkin' bout willis? the cost?
LOL.
heres a list of what your going to need to buld an ls/vtec the right way:
1. vtec head (your choice of head)
2. Golden eagle ls/vtec conversion kit ( comes with head gasket)
3. Arp headstuds (depends on which head you are going to use)
4. GSR oil Pump
5. GSR water pump
6. Timing belt (depends on which vtec head you use)
7. GSR rod and crank bearings (very important if you want to have a reliable motor.
8. B18a/b or B20 block
9. GSR P72 ecu Or a chipped P28 ECU
10. Knock sensor.
11. Ls high compression pistons or Ls Forged turbo pistons:
(Because you aren't going to really feel the difference from gsr to ls/vtec even though there is a power difference + you are going to get bored and want more power and at least you will have the bottom end taken care of whether you want to turbo or have a more powerful N/A Set-up depending on what you want!)
12. A full Integra Type R Tranny if you stay N/A, if you turbo stay with a gsr tranny and buy an LSD!!
Modified by god of war at 7:00 AM 4/17/2007
4. GSR oil Pump
5. GSR water pump
10. Knock sensor.
