Need suggestions on my current build, What I got, What I need.
dc2 chassis, itr front end.
I'm wanting to make 300whp-350whp on roughly 12psi. (pump gas) and 450+whp on race gas... psi is the limit. Car will fully be a street car.
current build....
b18c sleeved to 84mm (ductile chromoly sleeves) Must be better than dart or erl... they're $2600. If anyone has heard of these or runs them please provide info to me. I'm not that knowledgable on the sleeving world.
cp 9:1 pistons
pauter rods
bearings and all arp hardware.
head
1mm oversized SS valves on intake side
dual springs
Ti retainers
Gsr cams
Need a suggestion on a headgasket
tranny is a stock gsr tranny in which i am adding itr lsd
exedy flywheel
need a suggestion on a clutch
debating on either avid or hasport mounts
hondata s300
lovefab ramhorn exhaust manifold
JG edelbrock intake manifold
I'm wanting to keep the stock throttle body because i want to keep Cruise control. (I have a lead foot.)
needing suggestions on what size and kind of turbo, fmic and piping, oil feed and drain line size, wastegate, BOV, and possibly some cams.
I don't plan on this car seeing high boost any time soon. So, meeting the 350whp mark is the aim whp for a while.
Thank you in advance.
current build....
cp 9:1 pistons
pauter rods
head
dual springs
Ti retainers
Gsr cams
exedy flywheel
hondata s300
Cometic 84mm headgasket
ERL superdeck or any one of the 15 places that sleeve blocks on here
Competition clutch stage 5
as for turbo you could go with a simple t/3-t4 or you could go with something
ballbearing like a GT30R variant.
hasport mounts
Precision intercooler, with a piping kit from spoolin or something like that from our
sponsers
Oil feed from stealthmode
tial 38mm and tial 50mm BOV
As for cams you would be fine with the stock GSR's but ITR cams and boost are a great combo
hasport mounts
sponsers
Pinhead
Jun 23, 2002 07:54 AM
