Code 22 (searched)
Old Apr 14, 2007 | 07:03 AM
wernhersey's Avatar
Default Code 22 (searched)
My eg with a d16z6 is throwing a code 22. I have searched and found what it might be but I haven't found anything on how to fix it. I just want to know what sensor is causing this and can I try to clean it. I know it is a v-tec issue but I don't know if it the solenoid or if its a switch. If someone could help me out it would be greatly apreciated. Thanks
Old Apr 14, 2007 | 09:45 AM
wernhersey's Avatar
Default Re: Code 22 (wernhersey)
I just tried cleaning it and that didn't work either. And I also forgot to mention that everything seemed fine after the swap, the v-tec was and is still working and there were no CEL's.
Old Apr 14, 2007 | 10:47 AM
JACER63's Avatar
code 22 is the oil pressure switch for vtec. replace oil switch and should solve your prob. i had a similar problem and switched fixed the issue. gl to ya
Old Apr 14, 2007 | 02:31 PM
wernhersey's Avatar
Default Re: Code 22 (JACER63)
Is this the oil pressure sending unit you are talking about? If so I have an extra one at home I will try it.
Old Apr 14, 2007 | 04:32 PM
19slocivic97's Avatar
not the oil pressure switch in the back of the block, its the vtec pressure switch, it should be near the vtec solonoid, also remove the vtec solonoid housing and make sure the screen isn't stopped up, i think that if your oil level was low it will also set the code
Old Apr 15, 2007 | 07:48 AM
wernhersey's Avatar
Default Re: Code 22 (19slocivic97)
The oil is new and full, I am going to try and switch the pressure switch. Thanks for the help.
mike_h22a1/cd5
Oct 20, 2013 02:15 AM
cioli
12
Feb 26, 2006 08:31 AM
drudy
Aug 7, 2005 05:59 AM
allnapower
Apr 1, 2005 08:22 AM
singlecamcrx
Nov 24, 2004 02:10 AM
