whats Radio Ignition?
Old Apr 13, 2007 | 04:23 PM
j_DC2_m's Avatar
Default whats Radio Ignition?
this thing is comfusing. sry bout the problem.
Old Apr 13, 2007 | 04:48 PM
EE_Chris's Avatar
Default Re: whats Radio Ignition? (j_DC2_m)
I think maybe I over-estimated your ability on 'getting' the Illumination wire, as I missed this thread before answering it, no worries.
You're looking for a switched +12v source. When the ignition key is 'on', the particular wire you're looking for will have +12v on it....thus supplying it to the radio only then.
Then you've got a memory wire, right? That needs to go to a non-switched source because if it got switched off, your radio presets would be gone after you turn the car off every single time.
Old Apr 14, 2007 | 04:32 PM
hall97civic's Avatar
ok, radio wires. You have three main wires for your radio to work. First you have ablack wire. this is your ground. Next you have what should be a yellow wire. this is a constant feed wire(always has current flowing to it, it allows your presets and what not to be there eveytime you turn your radio back on), and then you have a red wire. This wire is a switced 12 volts (only power when you turn the key on). This tells the radio to turn on.
later,
robert
civicorprelude6
Audio / Security / Video
Jun 5, 2010 09:29 PM
TheLudeMan
Jan 13, 2008 12:33 PM
killacrx1
May 27, 2006 12:26 AM
KrispyKreme
12
Mar 17, 2005 01:13 PM
tyflip2
Jun 14, 2004 03:08 PM
