obdo ls/vtec w/b18b bottem end (do i need the knock sensor?)
Old Apr 13, 2007 | 01:29 PM
projectef's Avatar
Default obdo ls/vtec w/b18b bottem end (do i need the knock sensor?)
im doing a ls/vtec 4 a friend. im leaving it obd0, n im using an bod2 block, but do i still need the knock sensor like the one on the obd0 block?
Old Apr 13, 2007 | 05:22 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: obdo ls/vtec w/b18b bottem end (projectef)
no, you can disable the knocksensor in your ecu (OBD-0 or OBD-1).
Old Apr 14, 2007 | 10:43 AM
Suck my DX's Avatar
Default Re: obdo ls/vtec w/b18b bottem end (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">no, you can disable the knocksensor in your ecu (OBD-0 or OBD-1).</TD></TR></TABLE>
yeah but why would you want to, it can hear what you cant always hear.. unless your trying to get away w/ some detonation in order to tune the motor to make the most power....that would be my only guess to disable it
Old Apr 14, 2007 | 06:17 PM
projectef's Avatar
Default Re: obdo ls/vtec w/b18b bottem end (Suck my DX)
so i can eliminate it, n still vtec will pop rite?
Old Apr 16, 2007 | 07:04 AM
Suck my DX's Avatar
you mean just run without it?
it will throw a code 23 i believe is knock sensor
you need to disable it with whatever tuning software ur using
Old Apr 16, 2007 | 11:39 AM
projectef's Avatar
wat u mean disable it? cuz im use a obd0 b16 ecu, den tune it later. but can u tune a obd0 ecu? im still not 2 good bout tuning ecu's
denraweb
May 11, 2009 06:25 PM
projectef
Apr 26, 2007 05:52 PM
stinkbox
Jun 13, 2006 08:55 AM
jdmrex91
Jun 4, 2004 11:12 AM
CHRIS 1.8
Sep 23, 2003 03:59 PM
