Wheel Spacers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sambo_666 »</TD></TR><TR><TD CLASS="quote">Just wanna bring the wheels out a little more. Just so they dont sit so far in the wheel arch. Gay reason, but hey.</TD></TR></TABLE>
Yes.
You will need extended wheel studs to get them out that far.
Yes.
unless the wheels and or tires are too wide for the stock or even aftermarket offset then I agree this is a foolish idea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg »</TD></TR><TR><TD CLASS="quote">
unless the wheels and or tires are too wide for the stock or even aftermarket offset then I agree this is a foolish idea.</TD></TR></TABLE>
Sounds to me like he has the stockers on.
You will get more cornering grip from adding spacers, because you are increasing the track width.
But at the same time, you are softening up the suspension too, because you are retarding the motion ratio. So the car would feel a bit sluggish in the left-right transition.
You are also increasing the scrub radius, making the steering response a bit slower.
These are the pros and cons. So in terms of handling effects, it's all about compromise.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 »</TD></TR><TR><TD CLASS="quote">Anything over a 5mm spacer, I reccommend longer wheel studs.</TD></TR></TABLE>
I just want to make sure that you feel this is thoroughly well considered, and that you're standing by an evident recommendation that 5mm spacers can be used with OEM wheel studs.
I'd also like to know from anyone using the H&R 5mm spacers from King if the included studs are exactly 5mm longer than the OEM DC2 ITR studs.
Thanks very much for any help you can provide.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton »</TD></TR><TR><TD CLASS="quote">
Thanks very much for any help you can provide.</TD></TR></TABLE>
Well, I'm going by my own personal experience. I have yet to be on track with the spacers, but from street abuse, I see nothing wrong. I'll let you know this weekend how they fare on track.
It probably depends on the wheel. On my Volks, I'm only able to get about 4.5 turns on the lug nut. I wouldn't feel comfortable at all taking that on a track, and wouldn't.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wai »</TD></TR><TR><TD CLASS="quote">You will get more cornering grip from adding spacers, because you are increasing the track width.
These are the pros and cons. So in terms of handling effects, it's all about compromise.</TD></TR></TABLE>
This is about as good of an answer as your going to get. Now, go install the spacers, drive it, and make your own decision
Newborn_
Apr 16, 2007 01:51 PM
EH3Civic
Mar 4, 2006 10:25 AM
dgc92civic
17
Apr 30, 2003 10:37 PM
