???High flow cat.???
Old Apr 12, 2007 | 06:13 PM
JDMjoe86's Avatar
Default ???High flow cat.???
Where can i get a high flow cat. for my 01 LS
Old Apr 12, 2007 | 06:19 PM
Formula's Avatar
Default Re: ???High flow cat.??? (JDMjoe86)
Random Technologies makes them, but I recommend running a test pipe if possible. You get a little more airflow and they are usually cheaper.
Old Apr 12, 2007 | 06:27 PM
JDMjoe86's Avatar
Yeah those are everywhere (test pipes) but i hear bad things about them noise and the fact that i have obd2
Old Apr 12, 2007 | 06:30 PM
Sam92Teg's Avatar
Default Re: (JDMjoe86)
I have seen Magnaflow/Carsound high-flo cats tested against test pipes and there was less than 2 hp gain, which can happen even if you ran the same car twice with no changes. They are very affordable too.
Old Apr 12, 2007 | 06:34 PM
Formula's Avatar
I run a test pipe on my EG with a custom exhaust and a ITR muffler and don't have any problems with noise, my car runs and sounds similar to a ITR. The only downside to a test pipe are emission test.
As far as dealing with the secondary 02 sensor there are companies that make dummy 02 sensors. I can't remember any right now, but do a search and I'm sure you can find several companies.
Old Apr 12, 2007 | 06:40 PM
JDMjoe86's Avatar
Thanks for the help, i hit a 18 wheeler retread on the interstate and jacked up my whole exhaust. I have replaced it with a Apexi World Sport 2 catback but i think it nailed my cat as well and it rattles at idle(i think). So i was just thinking about replacing it
Old Apr 12, 2007 | 06:57 PM
ac_attak's Avatar
Check the cat heat sheild, very common for those to be rattling
Old Apr 12, 2007 | 09:53 PM
jorge59la's Avatar
Default Re: (ac_attak)
test pipes are good just dont get caught (cops) or else!!!!.......
allstarr7
Apr 1, 2008 06:42 PM
mugenspoongsr
Aug 22, 2005 02:04 AM
Malice
Oct 31, 2003 01:57 PM
YellowR2000x2
Apr 8, 2003 01:22 PM
TURBOED-TEG
Apr 5, 2002 03:21 PM
