Noisy transmission, sounds like a grind stone intermittently
Old Apr 12, 2007 | 12:17 PM
ProjectDarkBlack's Avatar
Default Noisy transmission, sounds like a grind stone intermittently
I know someone has had this. My transmission has been getting progressively noisier for the last two months. I already searched but no one could explain it well enough for me to understand if the had the same problem. It sounds like a grindstone sometimes, especially when it is cold, at idle mostly. Under accel it goes away, with the clutch in you can hear it about 1/2 the time, it will do it in nuetral with the clutch out also. So do you think it is the input shaft bearing? and, should I stop driving it right now?
Old Apr 12, 2007 | 09:57 PM
Default Re: Noisy transmission, sounds like a grind stone intermittently (ProjectDarkBlack)
Old Apr 12, 2007 | 10:03 PM
deegz's Avatar
my guess would be bad bearrings? time to rebuild or replace. no way to tell without cracking it open....
Old Apr 12, 2007 | 11:09 PM
Blahblah718293's Avatar
Default Re: Noisy transmission, sounds like a grind stone intermittently (deegz)
sounds like my problem. a shop told me i need a new tranny but i cant afford it now, so im gonna try replacing the fluid with synchromesh and hope that makes it last a little longer.. it doesnt help that i grind a gear at least like once a week, sometimes twice.
Old Apr 13, 2007 | 12:35 PM
Default Re: Noisy transmission, sounds like a grind stone intermittently (Blahblah718293)
this sucks. I have to drive it today :-/ My hg change should be done on my CRX tomorrow though
headrec*
Transmission & Drivetrain
Aug 29, 2008 08:49 PM
B00STED Si
Aug 30, 2005 04:00 PM
brx017
Mar 9, 2004 08:42 AM
95BlackGS-R
Jun 3, 2002 12:47 PM
