timing belt replacement questions
Old Apr 12, 2007 | 07:23 AM
mrmanuke's Avatar
Default timing belt replacement questions
A few questions. Should be pretty easy. I searched already.
1) How long does it typically take to replace a timing belt and timing balancer belt while the engine is in the car? I know it depends on experience, so I just want to know about how long it took some of you when you did it for the first time. I have read the Helm's through a few times so I have the basic procedure nearly memorized.
2) Do I need to get under the car to do the rear balancer belt shaft alignment, or can I reach the area through the wheel well area? Do I need to get under the car for anything else?
3) Related to the last question, should I put the car up on jack stands while I'm doing the timing belt work? I'd rather not if I don't have to.
Old Apr 12, 2007 | 07:46 AM
Hawkze_2.3's Avatar
Default Re: timing belt replacement questions (mrmanuke)
If you've never done it before it should take a while to do it right. Getting the belts back on is kinda hard the first few times.
I would definately take the time to put the car on jackstands. It will make it much easier to get to stuff.
Have you thought about leaving the balance shaft belt off? It's just personal preference, but it will give you a bit more power and it'll be easier to finish the belt job. It just makes a tad more vibration...
Old Apr 12, 2007 | 02:08 PM
TheWalrus's Avatar
Default Re: timing belt replacement questions (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
Have you thought about leaving the balance shaft belt off? It's just personal preference, but it will give you a bit more power and it'll be easier to finish the belt job. It just makes a tad more vibration...</TD></TR></TABLE>
agreed...i barely felt a difference when i took mine off. just drop the belt and leave the shafts alone otherwise
Old Apr 12, 2007 | 02:57 PM
m00nr0ck Si's Avatar
Default Re: timing belt replacement questions (TheWalrus)
It took me about 4 hours to complete my first timing belt change, just take your time and follow the book. Double check your timing marks before you fire it up and make sure you set the belt tension properly or it will whine like a spoiled biotch....
btw- put it on jack stands and be prepared to crawl under the car.
Old Apr 12, 2007 | 03:06 PM
esedulerp5tenin's Avatar
Default Re: timing belt replacement questions (dorkoftheyear)
i'm def gonna need this information when i attempt my oil pump next weekend
Old Apr 12, 2007 | 08:29 PM
mrmanuke's Avatar
Thanks guys! I feel like I'm pretty much ready to tackle this. I'll take my time with it and hopefully I'll be able to finish in 4 hours too.
Comp97GSR
Dec 30, 2022 12:10 PM
cavrdave
Jul 18, 2011 09:17 AM
Kellindal
Dec 1, 2007 02:20 PM
Stealthman80
Oct 25, 2005 09:12 PM
JiggaFan
Feb 21, 2003 09:52 AM
