Timing Belt Question - Honda-Tech - Honda Forum Discussion
Old 07-18-2011, 09:08 AM   #1
cavrdave's Avatar
Default Timing Belt Question
There are two belts when I pull up the parts diagram on the Honda Estore for timing belt. What is the second belt all about? It says something to the line of timing balancer and I'm assuming it's a good idea to replace it as well since I'll be there replacing the h2o pump and timing belt.
cavrdave is offline   Reply With Quote
Old 07-18-2011, 09:17 AM   #2
H-T Order of Merit
TouringAccord's Avatar
Default Re: Timing Belt Question
the second belt drives the balance shafts, and yes it should be replaced when replacing the timing belt.
here is a write-up that covers replacing the balance shaft belt, just for reference...
TouringAccord is offline   Reply With Quote
timing belt skips vtec_01 Acura Integra 5 12-12-2011 05:14 PM
Timing belt replacement gnx547 Honda Accord (1990 - 2002) 7 07-24-2010 12:01 AM
Timing belt abstraction Honda Accord (1990 - 2002) 4 08-20-2004 11:53 AM
how to tension timing belt extrmeboost Tech / Misc 17 05-31-2004 06:46 PM
timing belt prelude7 Honda Prelude 4 03-31-2003 08:55 AM
accord, belt, h2o, honda, pump, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
