Transmission problems
Old Apr 11, 2007 | 09:37 PM
Mugensr's Avatar
Default Transmission problems
Ok so she's an 01 R with roughly 75000 on the odometer as far as i know the clutch has not been replaced i'm the third owner and i've had all the mateniance done from 49.000 when i got it. This is what she's started doing recently if i'm slowing down in second gear and only in second gear it will pop out of gear if i try to shift into second when turning it wont go into gear and sometimes if i'm in reverse it wont move and the stick gets stuck in reverse. Also when i try to shift into second at a high rpm say 7-8k it sometimes grinds and will pop out of gear. I've checked the shift linkage its fine, I've checked the fluid also fine, the clutch master cylinder also checks out ok. So i'm thinkin maybe the synchros or something else internal but could the clutch being worn out be causing all these problems or is it time for a new tranny? or what else could it be? Any help would be greatly appreciated.
Thanks
Ted
Old Apr 11, 2007 | 09:41 PM
00TypeR1071's Avatar
Default Re: Transmission problems (Mugensr)
most likely its your synchros. I had the same problem in my Civic.
Old Apr 11, 2007 | 09:42 PM
_HANS's Avatar
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
Default Re: Transmission problems (00TypeR1071)
very common
Old Apr 11, 2007 | 09:50 PM
Mugensr's Avatar
Default Re: Transmission problems (4F_HANS)
so most likely time to get a new transmission dang it well thanks guys.
Old Apr 12, 2007 | 09:56 AM
SoCal ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugensr &raquo;</TD></TR><TR><TD CLASS="quote">so most likely time to get a new transmission dang it well thanks guys.
yep, that's more than just synchros.
nocturnal_sol
Mar 25, 2008 04:29 PM
JDMGSR-T
Oct 27, 2006 02:48 PM
shorty10388
Sep 17, 2005 12:49 PM
eMbrace
May 14, 2005 07:47 AM
91_2.0_Si
May 20, 2004 07:05 PM
