Oil pressure guage install?
Old Apr 10, 2007 | 06:47 PM
jdmturbo1127's Avatar
Default Oil pressure guage install?
Where is the best way to do it and how? I am using a mechanical guage....
Old Apr 10, 2007 | 06:54 PM
xXFiendxx's Avatar
Default Re: Oil pressure guage install? (jdmturbo1127)
Run whatever form of line you are using from t that is split off the back of the block through the firewall. I would recomend steel braided for mechanical gauges. As for power, tap into whatever power source that comes on when the lights are on. What kind of car is this going in?
Old Apr 10, 2007 | 06:58 PM
Default Re: Oil pressure guage install? (xXFiendxx)
98 civic EX with the single slammer D16.
Old Apr 10, 2007 | 07:18 PM
nighttrain33's Avatar
Like Fiend said, it is pretty straight forward. You need a 2-way screw that screws into the block to your t-fitting. Then you connect the stock pressure sensor to one end and the line running to your gauge to the other end of the t.
-Shane
Old Apr 10, 2007 | 09:29 PM
Default Re: Oil pressure guage install? (nighttrain33)
Sounds like cake, but how big of a T fitting will I need? How big is the hole where the stock pressure sensor is?
Modified by jdmturbo1127 at 10:42 PM 4/10/2007
Old Apr 10, 2007 | 09:47 PM
If you can find a specialty auto parts store (not Autozone) just tell them what you need it for and what kind of car it is for and they will be able to give you what you need.
-Shane
Old Apr 11, 2007 | 09:27 AM
Thanks. Would it be better to use an electric one instead? I heard that you would get more accuracy from a mechanical one... is this true?
frostbite21
Apr 17, 2006 10:28 PM
teler86
Jun 14, 2005 05:20 PM
PM-Performance
Dec 28, 2003 06:46 AM
Scary1109
Dec 3, 2002 03:55 PM
NeXtLeVeL_TyPe_R
Oct 2, 2001 09:50 PM
