guage installation
I want to put an oil pressure and a water temperature guage on my gsr. i would like to use the electrical autometer guages. has anyone done this? and is there a problem with using the electrical guages? is the install difficult?
Thanks
Scary
Thanks
Scary
installation is pretty easy.. just make sure to ground the sending units..
you will need to run a line of the block for the oil pressure
you need a BSP to NPT adapter to make this work
you dont want the sending unit hanging of the block.
Yea all you gotta do is "T" it from the stock oil pressure sender on the back of the block.... I personally like the electronic senders over running a line into the cabin of your car with oil pressure in it to a mechanical gauge... Good Luck
Petah
19
May 6, 2002 05:41 AM
NeXtLeVeL_TyPe_R
Oct 2, 2001 09:50 PM
