camshaft
Old Apr 10, 2007 | 04:28 PM
krazeenoy's Avatar
Default camshaft
can i put a stage 2 camshaft on my stock ls
Old Apr 10, 2007 | 05:28 PM
Sam92Teg's Avatar
Default Re: camshaft (krazeenoy)
Well seeing as you have a DOHC engine, nope, you need two cams. And since different companies have different specs for their Stages, there's no way for us to advise you. Who knows what cams your looking at. Try to search, tons of info. Try searching for Crower 403 cams, those posts should fill you in.
Old Apr 10, 2007 | 10:22 PM
unknown0001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazeenoy &raquo;</TD></TR><TR><TD CLASS="quote">can i put a stage 2 camshaft on my stock ls</TD></TR></TABLE>
You might want to look into the crower 403's but depends how you want to mod the LS engine as you might need to pickup aftermarket valve springs and retainers
are there specific cams your looking at?
Old Apr 10, 2007 | 10:31 PM
red01teg's Avatar
Default Re: camshaft (Mr.RHTuner)
valve spring upgrade is strongly advised as well as tuning. while ur messing with the head why not buy some sprockets too?
Old Apr 11, 2007 | 02:37 AM
tomlinson619's Avatar
Default Re: camshaft (red01teg)
u would probably see better gains with a stage1 since ur stock
Old Apr 11, 2007 | 08:52 AM
unrivaledintegra's Avatar
i'm having the same problem i want to buy crower stage two shaft with titanium valves an retainers on my da i got header stage 3 clutch e.c.u and wanted to know if stage two would b good if i wanted to turbo later
Old Apr 11, 2007 | 11:52 AM
Default Re: camshaft (unrivaledintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unrivaledintegra &raquo;</TD></TR><TR><TD CLASS="quote">i'm having the same problem i want to buy crower stage two shaft with titanium valves an retainers on my da i got header stage 3 clutch e.c.u and wanted to know if stage two would b good if i wanted to turbo later</TD></TR></TABLE>
what is this 'stage 2'
Post up the link of the camshaft instead of this 'stage 1 and stage 2' bullshit
Old Apr 11, 2007 | 12:39 PM
1.8L_allmotormilitia's Avatar
get dual valve springs and run 402-404 crower cams w/ tune.
Old Apr 13, 2007 | 04:46 PM
revolutionz_integra's Avatar
would definetly look into it more and cams aren't going to do to much but tuning is huge
b19coupe
Jan 20, 2013 06:03 PM
93LsVx
Mar 6, 2009 06:40 AM
y-49
Aug 10, 2008 03:16 PM
spuddo01
Jan 13, 2007 07:54 PM
guttedgentwo
May 16, 2003 08:49 AM
