LS cams?????
Old May 14, 2003 | 11:18 PM
guttedgentwo's Avatar
Default LS cams?????
looking for info about LS cams. looking at Crower stage 3 or 2 and i am just looking for some people that have tried different cams or the Crower cams.
Old May 15, 2003 | 12:05 AM
OneThirtyEight's Avatar
Default Re: LS cams????? (guttedgentwo)
crower 403's were great for me. Good top end, you have to raise your redline to 8+k to really feel them though.
To really feel the cams you have to get some ITR pistons and fully built head like I had, then you can have some fun runnin the LS to 8500rpm Really flys up there with the right kinda work.
Old May 15, 2003 | 01:22 AM
Default Re: LS cams????? (97blackteg)
i have an ECU to rev to 8,5 so no problem there. did you have any problems with your idle? did the cams make any power at the low to mid range area? and is it possible to hit that redline with the stock valve springs or just go ahead and put the dual springs in while im in there.
Old May 15, 2003 | 04:11 AM
arw321's Avatar
Try http://www.coltcams.com
Don't rev a stock LS to anything over 7500. And I wouldn't even do that often.
I'd only rev to 8000 rpm with a decent valvetrain (springs at least) and some ARP rod bolts.
Then you SHOULD be pretty safe. I still don't think I would make it an every occurence though.
Adam
Old May 16, 2003 | 08:26 AM
Default Re: LS cams????? (arw321)
*edit
I had a fully built head/motor so I could rev there safely.
Old May 16, 2003 | 08:29 AM
TeamSTEALTH GSR's Avatar
ITR pistons with LS head wont work...
P.s. i think web cams makes cams for LS app..
Old May 16, 2003 | 08:48 AM
arw321's Avatar
Default Re: LS cams????? (TeamSTEALTH GSR)
ITR pistons with an LS head WILL work. I dont' know where you are getting your info from.
If you are using stock LS rods they will have to be machined. Other than that there is no reason why they wouldn't work.
I have CTR pistons for my LS block.
Adam
Old May 16, 2003 | 08:49 AM
ya I had ITR pistons on my LS. You have to trim the rods a little but not much.
b19coupe
Jan 20, 2013 06:03 PM
LaOstha
Aug 3, 2006 09:16 PM
bananacruzier
Feb 22, 2002 09:56 AM
SoSoJeff
Feb 3, 2002 06:30 PM
