Shifting problems.
Old Apr 10, 2007 | 02:40 PM
gooberwolf's Avatar
Default Shifting problems.
I have a 2001 base manual prelude with 61K miles.
Recently I noticed it was really hard to put into 1st from a stop. I then heard a noise coming from the tranny, a light whining sound when I put it into any gear at stop with the clutch pedal depressed ofcourse. There was grinding when I put the gear into second from first at low speeds. Clutch fluid looks ok / no leaks on the master and slave cylinders. Is this common on 60K prelude? What would it be? Could it be synchros? Tranny fluid?
Old Apr 10, 2007 | 04:05 PM
britishdude's Avatar
Default Re: Shifting problems. (gooberwolf)
Try changing the tranny fluid with new Honda MTF, it will be smoother.
Old Apr 10, 2007 | 07:21 PM
shhh151's Avatar
Default Re: Shifting problems. (britishdude)
how old is your clutch???
Old Apr 11, 2007 | 08:24 AM
gooberwolf's Avatar
Default Re: Shifting problems. (shhh151)
original w/ car
Old Apr 11, 2007 | 07:27 PM
shhh151's Avatar
when i was having clutch problems when i put it into first at a light somethimes it would engage and jerk the car and also it would block me from going into first gear. when i did change my clutch i found out my clutch bearing was cracked in half and broke into two when it hit the floor!
first do the little things first:
bleed your clutch
tranny fluid flush with Honda mtf (new one with white cap)
niceprelude
Nov 7, 2008 10:22 AM
pcorad
Jul 28, 2008 05:42 PM
honda4674
Oct 24, 2005 07:39 AM
reeder321
12
Dec 31, 2003 07:29 AM
p0pe
Sep 27, 2002 05:11 PM
