IT RUNS!!!!!!!!
Old Apr 10, 2007 | 12:59 PM
Mandark06's Avatar
Default IT RUNS!!!!!!!!
i got it running, it turned out to be the ignition coil, but i just need to adjust my ignition timing from when i took off the distributor... problem is i dont have a timing light and i can't afford to go buy one.
any suggestions??? i came too far to just give up now hahaha = P
thanks to everyone that helped me out though, seriously haha i feel like a genius.
Old Apr 10, 2007 | 01:03 PM
lbcracing's Avatar
Default Re: IT RUNS!!!!!!!! (Mandark06)
i thought u dont use a timing light on honda's? jus line up the TDC lines. but i could be wrong. im still classified as a newb. or you could get an djustable cam gear on ebay?
Old Apr 10, 2007 | 01:07 PM
Mandark06's Avatar
no i'm not talking about the timing belt, my distributor... i have to adjust the ignition timing but i don't know where it's supposed to be cause it's only differential by two degrees. i mean is it safe to just turn it little bit at a time and keep trying it?
Old Apr 10, 2007 | 01:46 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mandark06 &raquo;</TD></TR><TR><TD CLASS="quote">i mean is it safe to just turn it little bit at a time and keep trying it?</TD></TR></TABLE>
What do you mean by "trying it"? There's no way to tell if you're within spec other than by using a timing light. You can find them for less than $25, or just borrow a friend's or neighbour's.
Old Apr 10, 2007 | 03:15 PM
Mandark06's Avatar
Default Re: IT RUNS!!!!!!!! (Padawan)
by "trying it" i meant starting the engine... so then whether it starts or not it's probably not safe to run the engine if i'm not within spec?
Old Apr 10, 2007 | 04:26 PM
ej14life's Avatar
I wouldn't try rotating the distributor without a timing light because how would you know what the setting is? A suggestion is once you have the timing set and you have to take the distributor off for any reason, you could mark the point where the distributor meets the head if you haven't purchased a timing light by then. It won't be 100% accurate but it will do.
Old Apr 10, 2007 | 04:31 PM
eg8tuner's Avatar
unless you have the dizzy 180 out it will run i perfer to star with it centered and le the car warm up then turn it a little and see how it sound then turn it the other way and see how it sounds the car should idle around 750 fully warm so check your tach and see what it's at after you move the dizzy.
don't take the bolts off just loosen them so you can turn the dizzy
(edit)
tis is only good for driving the car for a little while (it's old school)
i would get a timing light before i go beating on the car just to make sure you are with in spec
Old Apr 10, 2007 | 08:16 PM
keenspeed94's Avatar
Default Re: IT RUNS!!!!!!!! (ej14life)
distributer only goes on one way!
Old Apr 10, 2007 | 09:15 PM
eg8tuner's Avatar
no it is only supposed to go one way but you can put it on 180 cause ive done it its only two tabs the line it up so its easy to flip it around
Old Apr 10, 2007 | 09:18 PM
muhaMan's Avatar
good to see that ur car is running
mine died like 2 weeks ago and im STILL trying to get it to run BUT my mom lost the keys so i cant even put anything on it until they get found or when i get a new set made
Old Apr 10, 2007 | 09:38 PM
SluggishDA's Avatar
congrats
Old Apr 11, 2007 | 04:43 PM
Mandark06's Avatar
Default Re: (eg8tuner)
what does flipping the distributor do??? o.O
Old Apr 11, 2007 | 05:05 PM
Mandark06's Avatar
Default Re: (Mandark06)
*bump
Old Apr 11, 2007 | 05:17 PM
eg8tuner's Avatar
if your 180 degrees out then it probly won't run but might sprut and sputter is it does start its doing to sound like ****
Old Apr 11, 2007 | 06:04 PM
eg_104's Avatar
congrats my man
Old Apr 11, 2007 | 09:23 PM
Mandark06's Avatar
haha ummmmm just out of curiosity, i've looked at a few things online and i'm still not sure, could someone tell me exactly how to use a timing light??? hopefully i'm gonna be heading out to pick one up tomorrow. thanks
Old Apr 11, 2007 | 09:27 PM
SCRev's Avatar
Congrats!
Old Apr 11, 2007 | 09:36 PM
Mandark06's Avatar
btw hahaha thanks for all the congrats = ) makes me feel special. i know you all remember that feeling when you all completed your first real project or did your first troubleshoot ; P
oh... and *bump
Old Apr 11, 2007 | 10:17 PM
Mandark06's Avatar
*bump
still wondering how to use a timing light... thanks = )
Old Apr 11, 2007 | 10:58 PM
Mandark06's Avatar
*b-b-b-bump... sorry guys
Old Apr 12, 2007 | 12:00 AM
homicydalboy's Avatar
hook the timing light to a ground. with the other cord hook it to the spark plug wire closest to the timing belt. Point it down at the crank pulley and line up all the pretty lines.
tctruong94
Apr 27, 2017 11:10 AM
NENET
Aug 31, 2010 11:01 PM
97gsrki
Nov 15, 2007 11:31 AM
adip315
Jan 28, 2007 04:48 AM
miksew
Jun 7, 2006 08:03 AM
