How do you take off a stripped bolt?
Old May 27, 2002 | 02:36 PM
is3oo's Avatar
Default How do you take off a stripped bolt?
The 10mm bolt on my valve cover is stripped and i can't get it off. How do you take it off?
Old May 27, 2002 | 02:39 PM
underrated99si's Avatar
Default Re: How do you take off a stripped bolt? (SiR II Ek)
get a smaller socket and hammer it on it to make it snug as a virging and then take off. That is what I did for my whell locks and it worked fine. Good luck
Old May 27, 2002 | 03:02 PM
is3oo's Avatar
Default Re: How do you take off a stripped bolt? (underrated99si)
Got it. Thanks bro.
Old May 27, 2002 | 03:03 PM
jdmjunkie's Avatar
stripped right? not rounded? if it's a stripped chrome grommet nut it's kind of a bitch my friend had that problem. what I did was cut the grommet with some really good cutting dikes and then stuck a screw driver under the nut adding pressure like if I was prying it and wrenched it off. I did it this way because he didn't have air tools.
Old May 27, 2002 | 03:12 PM
NismoNX's Avatar
Default Re: How do you take off a stripped bolt? (jdmjunkie)
Ahh, nothing like a stripped bolt to **** you off.
Potential2nr
Jan 17, 2012 03:47 PM
spidermancivic
Aug 11, 2007 08:17 AM
itr1244
Aug 5, 2007 11:19 PM
murmur9
Mar 10, 2006 05:06 PM
Batoutahell
Oct 15, 2002 04:33 AM
