new swap... high idle...black smoke when Vtec hits...what's the problem????
Old Apr 10, 2007 | 02:22 AM
CHAMPwhteEK's Avatar
Default new swap... high idle...black smoke when Vtec hits...what's the problem????
I have a b16a2 head on a JDM GSR blcock and JDM GSR tranny and was wondering why is black smoke coming out when vtec hits and the swaps been in the car for some time...was wonderiing how too fix this problem
Old Apr 10, 2007 | 02:37 AM
spork motorsports's Avatar
* B A N N E D *
Default Re: new swap... high idle...black smoke when Vtec hits...what's the problem???? (CHAMPwhteEK)
black = rich
Old Apr 10, 2007 | 02:42 AM
FerioRallyB16a's Avatar
Default Re: new swap... high idle...black smoke when Vtec hits...what's the problem???? (spork motorsports)
it might be rich..
balance the fuel/air ratio
black smoke...
i heard that if car smokes black smog when car is fully warmed up, it might be the block problems but like i said, i Heard it so...
bad rpm idle maybe caused by bad idle valve...
on my H22 accord, it was idlen' bad, up n dow from 600-1k rpm
i took out the idle velve, took it apart, reverse the spring inside of valve, and cleaned it, it was fine..
i have saved cost for new idle velve and i didn even call gieco...
good luck
from fellow b16a2 lover
Modified by FerioRallyB16a at 4:08 AM 4/10/2007
Modified by FerioRallyB16a at 4:09 AM 4/10/2007
Old Apr 10, 2007 | 02:51 AM
Default Re: new swap... high idle...black smoke when Vtec hits...what's the problem???? (FerioRallyB16a)
If I was too take it too a shop what should I tell them too inspect and how much am I planning on spending
Old Apr 10, 2007 | 03:13 AM
* B A N N E D *
depends usally 100 an hour in labor alone
Old Apr 10, 2007 | 05:38 AM
blackKready's Avatar
really wont hurt it dude. rich is better than lean in most cases.
Cameron k.
Sep 13, 2012 01:23 PM
dizzyroc88
Jun 20, 2008 10:08 PM
blackjdmEKcivic
Feb 1, 2005 03:47 PM
HiChanDC2R
Aug 16, 2004 10:13 PM
1.8T_EG
Jan 28, 2003 03:26 PM
