Oil temp/press question
Old Apr 9, 2007 | 05:34 PM
hangac1093's Avatar
Default Oil temp/press question
I was just wondering if anyone could tell me what the ideal oil pres. and oil temp. are for a 1990 boosted integra. I just got a SPA dual digtal gauge with oil press./temp. and it has alarms for high/low temp and pres. That I need to set.
any info would be great thanks.
Old Apr 9, 2007 | 09:09 PM
Rikter's Avatar
Oil pressure.. on ym boosted DA I see about 70-85 accelerating.. 60ish just feathering the throttle to maintain a regular speed... and about 20-25 sitting at idle.
-Rik
Old Apr 10, 2007 | 07:16 AM
Sam92Teg's Avatar
Default Re: Oil temp/press question (hangac1093)
The Helms states minimum specs for oil pressure: B18A (1992)
10 psi at 750 rpm warm idle
50 psi at 3K rpms warm
Your pressures will be considerably higher, like mine:
92 RS B18A with 303K miles
17 psi at 750 rpm warm idle
70 psi at 3K rpms warm
I don't really know what would be a good minimum setting, maybe a little over minimum specs. And I don't know what max temp or pressure specs should be.
tegdude227
May 20, 2007 04:14 PM
LSVTEC 91 Civic
May 25, 2004 05:56 PM
TurboCX
Aug 3, 2003 06:33 PM
coil222
Jul 13, 2002 03:43 PM
obnoxius
May 22, 2002 05:53 AM
